Old 08-09-2021, 06:39 PM   #1
bsimms89
bsimms89's Avatar
Drives: 2012 SS/RS Vert & 2017COPO#23 SC350
Brake line fittings won’t fit
I’m trying to splice in a tee fitting for a pressure sensor on one of the rear brake lines on my 2012 convertible. I’ve done this before on other cars with 3/16 lines and never had an issue. I just use a -3an tee fitting and flare the two parts of the existing tube where I made the cut and then bolt it in. In this car even though the brake line is 3/16 there is a hard plastic coating over it. Due to this coating the tube sleeve for the AN flare does not want to slide over the end of the tube. I checked it with a dial micrometer and am getting a diameter of roughly .20 this seems to be due to the coating on the oem brake lines. Has anyone ever dealt with this before or know a simple way of removing a few inches of the coating? Any help would be appreciated.
2012 IOM Camaro Convertible 2SS/RS, A6/L99, ARH Longtube headers, high flow cats, x-pipe & mufflers
CAI Cold Air Intake, Kaltech Tuned
2017 COPO #23 Black w/ Supercharged LSX350
2014 Raptor 6.2L Tuxedo Black Metallic w/ 2.9L Whipple, 78Lb/hr fuel injectors, Ford Racing Dual 65mm cobrajet throttle body, kooks headers & exhaust.
1969 Camaro SS (original SS350), Black w/ white Rally Stripes, new ZZ502ci 502hp motor, muncie 4 speed, 4.11 rear
bsimms89 is offline   Reply With Quote
Old 08-10-2021, 02:00 PM   #2
bsimms89
bsimms89's Avatar
I sanded the coating off with a die grinder with a sanding wheel then the tube sleeve was able to slip on.
