Old 08-11-2021, 03:32 PM   #1
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Aux Battery Relocation Bracket
Does anyone know where I can get this bracket other than brutespeed.com? They want to charge $58 dollar for shipping on that. TIA
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 08-11-2021, 05:38 PM   #2
AlanRubin
Banned
Drives: 2010 LS
You don't want the AUX battery in the engine compartment if you want it for AUDIO
equipment. There is nothing in the engine-bay that would need an Aux battery, and
that would not end up powering more than you need.
Your RADIO and AMP power sources are in the trunk fuse box; F2 & F3.
I had the same deal with my former '07 Charger, so I put a full size AUX battery
in the trunk, and wired the AUDIO system to the Aux battery, so all the audio
and accessories I added ran off the AUX battery.
SO, if you happen to be looking to run your AUDIO from the AUX battery, it needs
to go in the trunk.
Connect the primary battery (+) to an 80 AMP isolating relay, then from relay to the AUX battery (+)
Connect the relay trigger so that the relay is only latched when the key is in the RUN position.
You want the batteries in parallel when the engine is running, and separated when in ACCY or START.
This way, when the car is in ACCY, the AUX battery provides the power source for the AUDIO.
Ground the AUX battery.
Pull the fuses F2 and F3 from the fuse box.
Run jumpered fuses from the AUX B+ to the fuse leg/side for the radio side and amp side, not the source side.
AlanRubin is offline   Reply With Quote
Old 08-11-2021, 06:06 PM   #3
760bowtie
760bowtie's Avatar
I’m not looking to put an aux battery in the engine compartment. I need to reinstall that battery post in the picture and need that black bracket to do it.
Old 08-11-2021, 06:48 PM   #4
Omega
Drives: G8
Contact ATI directly or one of their dealers. I doubt you will find it much cheaper though
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 08-11-2021, 07:12 PM   #5
760bowtie
760bowtie's Avatar
Yea I don’t mind paying the $38 for it, but $58 on top of that for shipping is ridiculous.
Old 08-11-2021, 07:22 PM   #6
Omega
Drives: G8
Next day delivery and white glove installation isn't cheap!
Old 08-11-2021, 07:28 PM   #7
760bowtie
760bowtie's Avatar
LOL that’s for USPS ground. Doubt that’ll get to me next day.
Old 08-12-2021, 07:38 AM   #8
gtstorey
For that type money I would make my own.
Old 08-12-2021, 11:27 AM   #9
760bowtie
760bowtie's Avatar
Ended up ordering directly from ATI.
Old 08-16-2021, 12:59 PM   #10
Adriangarza40
Drives: 2014 2SS/RS/LS3
Did you find it on their website or did you call? im looking for one as well
2014 LS3, AFDynamics Cai, Speed Engineering catless headers, BTR Nightfury cam 484RWHP 453lbft TQ
Adriangarza40 is offline   Reply With Quote
Old 08-16-2021, 01:03 PM   #11
760bowtie
760bowtie's Avatar
I called them and ordered it. They shipped it out same day.
This is the number I called 913-338-2886
