Old 08-17-2021, 06:12 PM   #1
Muscle SS
All blackkk
Drives: 2010 2SS/RS LS3
130k miles, looking to bring my suspension back to life
My poor 2010 Camaro SS has seen 130k miles of hard daily driving in NYC.
One of my struts has completely blown out, and I figured it’s time to update what I can.
So far I’ve order new struts and spring for all 4 corners, new sway bar stabilizers for the front and rear, the Eibach front and rear sway bar kit, BMR trailing arms, BMR outer trailing arm bushing kit, BMR toe rods, and a BMR rear upper control arm bushing kit.
Is there any other thing I should have swapped out while I have her at the mechanic?
Any and all comments, recommendations, and otherwise are appreciated!
Drivin it like I stole it.
Muscle SS is offline   Reply With Quote
Old 08-18-2021, 06:55 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
You could do the FE4 conversion, but you would need a different rear bar, FE4 LCAs and end links. The factory 1LE bars are actually pretty good.
Old 08-18-2021, 07:49 AM   #3
Axe55
Drives: 2012 Camaro SS
I'd throw in BMR cradle bushing inserts or the solid cradle bushings. The inserts are easy to do and I've been ok on mine for 2 years. I daily mine, it hasn't seen a track yet so I didn't go solid.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
Axe55 is offline   Reply With Quote
Old 08-18-2021, 09:13 AM   #4
gtstorey
Yes, if you can return the parts already ordered, would recommend FE4 conversion.
https://www.camaro5.com/forums/showthread.php?t=363659
Old 08-18-2021, 09:17 AM   #5
Bigdumogre
Bigdumogre's Avatar
Seems like you got it all covered pretty much. New tie rods inner and outer for the front are pretty cheap since you need a alignment anyway wouldn’t hurt to change those too.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 08-18-2021, 10:22 AM   #6
CamaroCracka
oh ya, there is also a front radius arm insert sold by Pedders and others. The factory even used them on the Z28. They are pretty cheap and a great upgrade.
