![]() Drives: 2012 Camaro Join Date: Aug 2021
HELP NEEDED
I got a 2012 with the 3.6. Woke up one morning for work and heard it knocking/ticking. PO303 is the only code (misfire cylinder 3) changed spark plug. No result. Swapped coils. No result. Friends that know more than me think it’s top of the motor. There’s also substantial blow by coming from oil fill tube and (pcv) tube. Any ideas? Rings? Valve? Knocking will go away at idol.
![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
What did the old plug look like?
Wet? Black? Is it actually getting spark?
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
![]() Drives: 2011 Camaro SS LS3 Join Date: Oct 2020
Is it the RS? Do you have any way to measure oil pressure?
I do not
Not an RS
#6 |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Then now you need to look at the injector on that cylinder. You've checked spark, now let's check fuel.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
#8 |
Before i went any farther i would double check just to be sure.
Fire it up, shut it off immediately and check for raw fuel on the #3 plug. If wet fuel is ok and probably a no spark condition. If dry then you might have a plugged/bad injector.
#9 |
Would that cause the “knocking”?
#10 |
Not having fuel in the cylinder while it is sparking
#11 |
And it would blow a ton of air back thru the PCV, etc.
| Tags |
| 3.6, knocking, ticking, v6 camaro |
