Old 08-19-2021, 06:40 AM   #1
Gachavez
Drives: 2010 camaro 2SS
Lightbulb Rebuilding LS3 with no part failures?
I have a 2010 2SS M6. As of right now my LS3 has around 115,000 miles on it. Well taken care of, with small bolt ons. I am aware that even at the mileage it has, these engines are very tough and stout, and it does still run perfectly fine. However my question is, would it be feasible to “rebuild” the engine with things like upgraded lifters, trunnions, gaskets, etc to help elongate the life of the engine and prevent problems before they happen or possibly negate some of the mileage? Wondering if it would even be worth the $$$, or time. I plan on keeping the car and driving it hard for a few years longer and would like to ease my mind knowing that it’s not going to blow up every time I head down to Mexico for races. Thank you in advance.
Gachavez is offline   Reply With Quote
Old 08-19-2021, 06:51 AM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I’d say you can do a top end refresh with parts mentioned an you be good for another 100k. I’d replace the oil pump an go with a LS2 tensioner/guide.
Orange Krush II
Old 08-19-2021, 07:16 AM   #3
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I would say your probably fine with your current mileage, BUT if you race it then there are certain things that I would do to ensure longevity. Like you mentioned the rockers are a weak point and che trunnions are a good investment as well as a good oil pump. I would recommend the melling 10355HV with the higher compression spring for sustained high rpm. I would also recommend plugging the oil bypass relief valve in the oil pan. There's a guy I read about that kept rebuilding his engines and swore he was getting trash in his bearings until he plugged it because of the higher rpm that he was running and which can be a double edged sword when running a high pressure oil pump without plugging the bypass valve because when you go over 50 psi the oil bypasses the oil filter and goes straight to the pan. And some racers say that you want all the pressure you can get at high rpm. So that's something to think about. And if your running a different camshaft then you would want a quality valve spring and lifters to go with your trunnions. You may also want to look into some tranny and oil coolers too like the mishimoto oil cooler and the tru cool 40k. Just my $.02
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 08-19-2021, 07:28 AM   #4
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Start building another engine on a stand. When you get the goodie out of the current one you will be all set.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 08-19-2021, 07:44 AM   #5
Omega
Drives: G8
I'm my opinion, if it ain't broke...
The only suspect item you have are the rockers which if they have lasted 115K I wouldn't worry too much about. It doesn't sound like you plan on putting a cam in, at which point, you would do new lifters, rockers, oil pump, OEM gaskets and maybe ARP head bolts
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 08-19-2021, 08:07 AM   #6
Gachavez
Thank you for your input, I really appreciate it. & I had little to no clue about plugging the bypass valve, that is infact something to think about
Old 08-19-2021, 08:08 AM   #7
Gachavez
Appreciate the advice, I’ll most likely do that along with some other ideas. Thanks!
Old 08-19-2021, 03:14 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Good advice here for sure...
Old 08-19-2021, 03:16 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
This is good advice too... I just refreshed my .660 valve springs after 23k on them, everything else was good..
ls3 5thgen, ls3 engine, ls3 mods, ls3 rebuild
