08-20-2021, 12:20 PM | #1 |
Drives: '12 Camaro 2SS/RS Vert Join Date: Oct 2020
LTH Install Troubleshooting
OK just wanted to run some things buy the experts. Installed used ARH LTHs, gutted cats/midpipes, new OEM plugs and Taylor 409 wires. New GM gaskets and I reused the O2 sensors, added extensions up front, and tied them back away from the headers. No tune as of yet.
I have some obvious exhaust leaks at the midpipes (slip joint and/or ball socket) that I continue to work on. What I'm also experiencing is a rough and low idle. The car feels like it wants to stall, especially in reverse. I checked the plug gaps before install and the only code I've triggered so far is the P0137 O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2). The car definitely feels stronger and seems to run just fine on throttle. Just REAL LOUD! Since I've never worked on one of these cars, I'm not sure if any of this is normal pre-tune behavior, if its the leaks, or if this this might be a plug/wire issue. Any tips would be appreciated!
2012 Camaro SS Convertible: 2SS, LS3, M6, Triple Black. Mods: Solo Axleback, 1LE FE6 rear swaybar, CAGS delete, Vararam CAI, Heritage grill, Hotchkis springs, '15 FE4 struts/shocks, ZL1 side rockers, Velgen Classic5 wheels, Pedders radius rod bushings, ARH LTHs, gutted HFCs,...
08-20-2021, 12:55 PM | #2 |
Drives: 15 Camaro SS Join Date: Oct 2018
Not exactly normal, but issues do pop up after lth install without a tune. I'm betting once you get a tune, she will run proper
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
08-20-2021, 01:39 PM | #3 |
The car just probably wants a proper tune. I would take it very easy until then.
08-20-2021, 01:56 PM | #4 |
Thanks guys! I'm definitely going to take it easy.
08-20-2021, 02:31 PM | #5 |
Did you remove the plugs when you were installing the headers? They break very easily when you’re re-installing them.
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list: Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket. |
08-20-2021, 04:15 PM | #6 |
Yep. Brand new plugs and wires.
08-20-2021, 04:20 PM | #7 |
My idle has always been low and from the factory almost felt like it had a misfire. Almost. However, after I put the headers on, it felt exactly like it did prior. Just louder and with a check engine light until I got the tune. If you feel it’s significantly different I would ohm check the wires and verify there isn’t any tracking down the side of the plug.
08-20-2021, 04:26 PM | #8 | |
Thanks for the tip on the wires.
