Old 08-22-2021, 05:23 PM   #1
Jsnipes36
Joshua snipes
Drives: 2015 Camaro LS v6
Please help with my 2015 camaro LS
Ok I’ve finally resulted in making a post. I have a 2015 camaro LS v6. I’ve had it since 62000 it rest now at 84,000. The codes I am pulling are po430 and p2099.
I’ve completely went back to stock intake as for I had a ingen CAI. Now it’s completely stock.
Prior to the po430 code I had po15b po15d po2097 which I fixed all and cleared.
Now recently driving home a month ago my car seemed like it had a heavy misfire and it showed service stability track check engine light flashing and the car seemed to lock up and wouldn’t go above 40mph or 2rpm.
When this happened i scanned the car for codes and got po430 p2099 po300
It’s been that way ever since stuck in limp mode if I push to hard it it’ll flash the check engine light. I am stuck with codes po430 p2099 in limp mode :( I just need my car back :(
Jsnipes36 is offline   Reply With Quote
Old 08-22-2021, 05:51 PM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Check the condition of the battery. Lots of problems occur with a bad battery. Might not be related but, worth the check.
0stones0 is offline   Reply With Quote
Old 08-22-2021, 06:33 PM   #3
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Id assume its your catalytic converter. Id replace your cat and o2 sensors.
With what your saying i assume its a clogged cat
Old 08-22-2021, 06:57 PM   #4
Jsnipes36
Joshua snipes
I’ve had the better checked multiple times and it always shows a healthy battery. @0stones0
As for the cat that’s what the dealer told me and they also told me that they couldn’t further diagnose because of the CAI and that may be the reason I’m in limp mode lol. So I returned it to stock and it’s still in the same condition.
Clogged cat? I did run cata clean when this happen and also I changed both downstream sensors also put extender same result.
Tuesday I am going to have it diagnosed by a repair shop that fits my budget plus I just don’t trust the dealer anymore.
What should they check for sure o2 readings while driving. @camaroDreams76
Old 08-23-2021, 12:40 AM   #5
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
Kepp us updated. I'm really curious.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 08-23-2021, 07:47 AM   #6
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
BATTERY!!
Car Nation Videos is offline   Reply With Quote
Old 08-23-2021, 09:59 AM   #7
Jsnipes36
Joshua snipes
It’s not the battery dude @carnantionvideos
Old 08-23-2021, 10:22 AM   #8
PaulsSS
Drives: 15SS Camaro
Could be a few things, to pin point it you will need to scan it and see why its not controlling the fuel. Most likely a bad MAF or like said a blocked cat.
PaulsSS is offline   Reply With Quote
Old 08-23-2021, 11:45 AM   #9
xstuntman
Drives: 2012 Victory Red LFX
Sounds to me like the drivers side cat is bad or the O2 sensor for bank two is bad.
V6 cars have bank two on drivers side IIRC.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 08-23-2021, 12:04 PM   #10
TastyBake
TastyBake's Avatar
Drives: 2011 Camaro 2LT/RS Black
My vote is O2 sensor(s) based on those three codes.
I would be very surprised if it was the cat as the car is pretty young w/ less than 100k miles.
TastyBake is offline   Reply With Quote
Old 08-23-2021, 12:43 PM   #11
Jsnipes36
Joshua snipes
The MAF Sensor was replac and the CAI was taken off back to stock. I also cleaned my throttle body 1 month ago when this happen. Tuesday I’ll be taking it into a shop for further diagnosing. They pretty much are gonna check fuel delivery and trims and o2 readings with the car on (live data). @paulsSS
Old 08-23-2021, 12:46 PM   #12
Jsnipes36
Joshua snipes
Another big symptom I’ve taken note of is seeing the oil pressure get to as loa as 0.7 on the dash at idle. Isn’t that low as hell? When driving it operates good… rides the rpm needle for the most part. only at idle or gets super low like 0.7 I’ve seen.
Old 08-23-2021, 01:52 PM   #13
Car Nation Videos
If it’s not the battery then it has to be a sensor.
Old 08-23-2021, 10:18 PM   #14
PaulsSS
Drives: 15SS Camaro
Very possible the pcm is bad too.
p2099 po430 po300 p2097 limpmode
