Old 08-23-2021, 11:27 AM   #1
cmack
Drives: 2011 Camaro SS
StopTech Stainless Steel Rear Brake Lines 950-62509
I searched and could not find any post on this part number.
Has anyone actually installed Stoptech rear stainless lines (950-62509)?
https://www.summitracing.com/parts/S...9/applications
The female fitting will not thread to the male fitting on hardline. It will make about 1 turn then the threads jam up. I tried two different sets, both had same problem. The stock lines, I can hand tighten all the way until the wrench is needed.
I already own the ST-60 BBK front kit there was never a problem with their front lines. They threaded fine.
Stoptech customer service confirmed it was correct part number and basically suggested something must be wrong with my hardline fittings. They did say they would investigate problem. For now - I am just returning them and staying with stock rear lines.
cmack is offline   Reply With Quote
