Old 08-23-2021, 02:46 PM   #1
SlingshotEngage
Dad’s Camaro
SlingshotEngage's Avatar
Drives: 2010 M6 2SS/RS Camaro
Thumbs down Crankshaft Pulley Issues
So... I had low oil pressure and decided to replace the oil pump as I know it is a common problem. I removed everything, replaced the crankshaft gear tensioner with the wishbone type from the LS2. I have issues getting the crankshaft pulley back on, so I tap it one with a large 32mm socket and a hammer(I did not hit it hard, not a lot of room in there to do so).
Then I go to rotate the crankshaft after putting the car in neutral. It doesn't turn. I try for a long long time, and a lot of different ways, 1-1.5 hours, but nothing is working. Shouldn't be that difficult anyways right? I think something might be bound up in the crankshaft gear, maybe something to do with the wishbone tensioner. As i am pulling off the pulley, it seems like it seized on the shaft and is bringing out the shaft with it. If there is already a thread on this, please point me in that direction. If not, please let me know what is going on, cause whatever it is, it doesnt seem good.
2010 2SS/RS M6 "Lady"
Vararam intake, SW headers, Corn kit, Tuned by PCM of NC.
SlingshotEngage is offline   Reply With Quote
crank pulley, crankshaft, not cool
