Old 08-25-2021, 02:56 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
It’s toasted.
Well car is done. Block is toast.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 08-25-2021, 02:58 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Noooooo! What happened?
Old 08-25-2021, 03:04 PM   #3
RupertPupkin
Carnage. Time for a rebuild.
730whp: 630Trq
Old 08-25-2021, 03:05 PM   #4
RupertPupkin
Did a 2nd gear pull, hit 6500rpms, and puff of smoke starts bellowing out the hood. Pretty much everywhere.
730whp: 630Trq
Old 08-25-2021, 03:16 PM   #5
bayarea408
bayarea408's Avatar
Drives: T
Did you use methanol for safety ?
bayarea408 is offline   Reply With Quote
Old 08-25-2021, 03:32 PM   #6
RupertPupkin
I had e85
730whp: 630Trq
Old 08-25-2021, 03:32 PM   #7
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
That sucks
What’s your plans for it now? Going bigger?
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 08-25-2021, 03:52 PM   #8
bayarea408
bayarea408's Avatar
Drives: T
Originally Posted by RupertPupkin View Post
I had e85
stock block needs more love at 800 wheel than inconsistent pump ethanol, sucks to hear man. It is extremely common and honestly apart of the formula for keeping stock motors alive at insane power figures. Whats done is done, new shortblock should be stout as hell made for this level.
Old 08-25-2021, 04:19 PM   #9
RupertPupkin
Back on the drawing board. Never been in this situation, so I don’t even know where to begin.
730whp: 630Trq
Old 08-25-2021, 04:21 PM   #10
RupertPupkin
More carnage.
730whp: 630Trq
Old 08-25-2021, 05:27 PM   #11
bayarea408
bayarea408's Avatar
Drives: T
well judging by you holding a piston wrist pin i "assume" the heads are toast too, damn.
Long block time, 6 bolt setup for 1300+ or LSA / Iron for around 1100 hp
LME, LMR, Texas speed, Thompson MS. reputable vendors to browse through
Old 08-25-2021, 05:40 PM   #12
RupertPupkin
Yeah. That’s what I’m assuming too. There’s too many options, and no clue what to look at. For now, I just have to scour the forum.
Option B. Sell the shell and trans and just get a C7Z.
730whp: 630Trq
Old 08-25-2021, 05:49 PM   #13
bayarea408
bayarea408's Avatar
Drives: T
I'd sell the blower kit, throw a stock motor in it and flip the car as a working 1Le, you get a nice penny for it. Then Z i want that ride sooooo much. Everyone drooling over C8's i want a C7Z LOLOL
Old 08-25-2021, 06:05 PM   #14
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Oh man that sucks.
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
