Old 08-25-2021, 11:01 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
NEW LONG BLOCK (boosted)
Engine took a dump. Looking at Thompson Motorsports or TSP. Anyone have any feedback? I know both of these guys are pretty reputable.
So far I have the Thompson block in mind, but no idea for TSP.
Thompson Motorsports Iron Block 1300HP DART SHPLSNEXT 427 1300HP w/ F710 Frankenstein Head.
TSP seems like it’s a little bit cheaper, but once I get the right setup/optioned out, cost might end up being the same.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 08-26-2021, 04:59 AM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I don't know. I've heard good things about Thompson Motorsports but have ordered lots of stuff from TSP and have been to their facility 3 times and really like it. And I can say their parts and customer service are top notch.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 08-26-2021, 07:35 AM   #3
eLeSthree
Drives: 2011 Camaro SS 6sp
Those heads are badass. What are you goals? Because you can save yourself $2000 if you stick with the M311 heads. Plus the cost of an LS7 intake. Maybe even new headers...
The ls7 style heads use a different intake port and the exhaust ports are raised a little, so headers may or may not fit/rub somewhere. Plus the rockers are different, but Im sure you plan on buying new ones anyway.
Be realistic with your goals, and dont forget, it is not easy to hook 1200whp on the street. lol.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 08-26-2021, 08:48 AM   #4
RupertPupkin
My goal:
-Keep the budget low. Lol
-Keep my aftermarket parts: ECS 1500, Ls3 intake manifold, speed engineering headers, ATI dampener, High Torque starter, FIC injectors. Etc…
If I can get something cheaper and support the power when I max out my blower, then that would be the route I would go with. I’m purposefully setting a plateau for my self. Not really looking to change out headers/intake manifold etc. Really just want to transplant as much of the after market parts to the new long block.
So many damn options. And when you start looking, in the back of my mind I’m saying “well it’s only x amount more for this…”
730whp: 630Trq
Old 08-26-2021, 10:16 AM   #5
gtstorey
I think a call to both would be in order to discuss your goals and let them put a package together.
Old 08-26-2021, 10:48 AM   #6
RupertPupkin
I emailed them.
730whp: 630Trq
Old 08-26-2021, 02:53 PM   #7
bayarea408
bayarea408's Avatar
Drives: T
ATTA BOY!! Dart SHP, this block is stronger than what that 1500 novi can provide. i think the novi 1500 is max effort around 900, but if you really plan to stay with the 1500 you can save more using a slightly lesser block. That Dart Block can handle way more than the rated 1300 as its a aftermarket 6 bolt racing motor. Headers off the stock motor setup might not fit the 6 bolt heads, definitely double check.
bayarea408 is offline   Reply With Quote
Old 08-26-2021, 04:36 PM   #8
RupertPupkin
That’s what I was thinking of, especially the more I read/research. I just thought of that combo since I know Elesthree has that combo. If I could save more money, I’m game. I’m still waiting for an email from them.
730whp: 630Trq
Old 08-26-2021, 04:47 PM   #9
RupertPupkin
Looking at this as another option. 2500$ Less for a Forged iron block.
https://www.thompsonmotorsports.net/...ion-m311-heads
730whp: 630Trq
Old 08-26-2021, 04:52 PM   #10
gtstorey
You might want to read through this, it discuss some of the Thompson Motorsports options.
https://www.camaro5.com/forums/showt...=588378&page=7
Depending on what you are doing with the car, at around 800hp I would stay with a production based aluminum block. Or to save money a production based iron block build.
Old 08-26-2021, 05:20 PM   #11
RupertPupkin
Planning on maxing out the 1500. That should be between 900-1000whp depending on setup.
730whp: 630Trq
Old 08-26-2021, 05:30 PM   #12
gtstorey
Same rating as the iron block
https://www.thompsonmotorsports.net/...kenstein-heads
Old 08-26-2021, 05:46 PM   #13
RupertPupkin
Saw that option also, but for 500$ more I could do the Dart 427. Advantage is that it’ll be lighter.
730whp: 630Trq
Old 08-27-2021, 10:16 AM   #14
gtstorey
Yes, I would just hate to add the additional weight on the front end, when you have already added the weight of the supercharger. If you are mostly drag racing/straight line acceleration it might not be worth more cost for the little less weight, but it will be that more nose heavy when turning.
