Old 08-27-2021, 12:11 PM   #1
Bennieficial
Bennieficial's Avatar
Drives: 2011 Synergy Green Camaro SS
Coolant flush question
I'm in the process of doing a coolant flush on my 2011 SS. I've drained and refilled with distilled water about 5 times. Now it's draining out pretty clear.
I know that there's still some stuff in the system, as our cars hold 3 quarts, but I'm not able to put in the full 3 quarts. So, my question is if I'm trying to achieve a true 50/50 mix, about how much percentage of coolant should I really be mixing with distilled water? Should I over compensate with a little more coolant than water (since it's draining pretty clear)? Or would I be safe just mixing 50-50 still?
Bennieficial is offline   Reply With Quote
Old 08-27-2021, 12:27 PM   #2
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
You are safe just mixing 50-50 and running it until it's full. I doubt you deal with -10° weather where a 60/40 water/coolant mix would be. Boiling points are negligible between these ratios.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 08-27-2021, 01:22 PM   #3
Rmkuper
Rmkuper's Avatar
Drives: 2010 Camaro SS
Yeah I wouldn't overthink it to much. Just be sure to burp it afterwards and check the temp regularly afterwards...
Sent from my SM-F916U using Tapatalk
Rmkuper is offline   Reply With Quote
Old 09-01-2021, 03:03 AM   #4
Bennieficial
Thanks! Overthinking is exactly what I was doing lol
