Old 09-03-2021, 12:32 PM   #1
Mr Cheekz 14
Mr Cheekz 14's Avatar
Drives: 2010 SS/RS M6
3:91’s?
Just have a question about 3:91’s. My car is a 2010 SS manual with the LS3. Here in the next couple weeks it’s getting an intake, headers and a tune. I’m in debate on if I should get 3:91’s as well. The reason I’m asking is because I don’t take the car to the drag strip. And if I did do any racing it would be at roll events with friends like the Pocono roll events. And those are 50-60 mph starts. I know they get you out of the hole faster but that isn’t really how I use the car. So would 3:91’s help or be noticeable? Thank you all.
Mr Cheekz 14 is offline   Reply With Quote
Old 09-03-2021, 01:50 PM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Seat of the pants feel you will enjoy the 3.91's. As long as you aren't going FI I would strongly consider 3.91's
Greenhornet2 is offline   Reply With Quote
Old 09-03-2021, 04:02 PM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
I would do it, Camaros need as much gear as you can get.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 09-03-2021, 04:03 PM   #4
Mr Cheekz 14
Is it just a seat of the pants feel or does it make the car a little quicker? I’m leaning towards getting them done.
Old 09-03-2021, 06:56 PM   #5
O.F.
O.F.'s Avatar
Drives: 2015 BLK/BLK 2SS/RS MN6
On the street, you can ease it out in first with no throttle. First gear is a quick shift up. It doesn't give you much. The rest of the shift points come up pretty quick too. Highway speed, you can drive in 6th at 55 without lugging it. For that matter, you'll be looking to go to 6th at around 55 under normal conditions. 100 mph comes up way too easy! I liked mine but never raced it.
O.F. is offline   Reply With Quote
Old 09-03-2021, 07:28 PM   #6
Mr Cheekz 14
I think I’m going to go ahead and get the gears. Now will I have a ton of wheel hop with I them? I have some fairly new Nitto all seasons on the car now. If need be I’ll grab some new tires for it.
Old 09-03-2021, 11:48 PM   #7
RupertPupkin
Drives: 2014 Camaro SS 1Le
Wheel hop not really.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 09-04-2021, 09:35 AM   #8
rdavis
Drives: 2012 SS
Ive had 3.91s in my car for about 4 years now, & would never go back, They make the car so much more fun & driveable. Even if you are not at the track. Also I would think that it would extend clutch life as not having to slip as much to get the car rolling.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
rdavis is offline   Reply With Quote
Old 09-04-2021, 11:03 AM   #9
sinlinson
2016 2SS Convertible
Drives: 2011 Camaro 2SS convertible
3.91's made a huge difference on my car. These are big cars and need more gear to get them moving. Before the swap 5th and 6th gears were so high I could drive in 4th on the expressway. Now I can use all the gears and don't have to be doing 100 to get it in 6th. Do it before you get the tune, so you don't need to retune.
sinlinson is offline   Reply With Quote
Old 09-04-2021, 06:41 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Just do like I did and install a 4200-4500 stall and keep the stock gear!! She really gets off the line very quickly, and I can still cruise at 75mph and keep the revs down, and save fuel too.. lol.
Old 09-05-2021, 11:35 AM   #11
Mr Cheekz 14
My car is a manual but if it wasn’t I would definitely get a stall. So from what I’ve heard 3:91’s are the way to go. So that’s the plan along with bolt ons. Thank you all.
Old 09-06-2021, 07:02 PM   #12
dino2012ls3
Drives: 2012 ls3
I run 4.10s manual with cam, headers, etc. I love them cause it really seems to put my car into that sweet rpm range.
dino2012ls3 is offline   Reply With Quote
Old 09-06-2021, 08:36 PM   #13
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
If you are staying NA, go for 4.10 gears. They make the car feel much lighter and it really helps get the car moving. You are leaving performance on the table if you install 3.91s, but they will be way better than the 3.45s currently in the car.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 09-07-2021, 08:10 AM   #14
Greenhornet2
Yes it makes the car faster as long as you are hooking.
