![]() Drives: 2015 Camaro 1LE Join Date: Mar 2014
ls3 camshaft not turning by hand after install
Hello everyone I have been wondering about an answer for this. I saw an install on a LS3 5th gen and the cam would not turn by hand after the cam gear was torqued down to spec for the ARP Bolts. However when the bolts were loosened the cam turned freely by hand. This was done with no heads on so spring pressure wasnt the issue. What would cause that issue because i have no answers for the guy other than pull it all back out and start over checking everything again. My guess was a lifter was in side ways or something but didnt stay long enough to verify it.
2015 1SS 1LE: BTR Stage 5 N/A cam, 1 7/8 Longtube headers, catless connectors, Z/28 Cold Air Intake, Vararam Power Wedge.
Upcoming Mods: GPI Ported heads GPI Ported Rodmod intake ZL1 Injectors DSX E-85 Flex Fuel Kit |
![]() Drives: 2014 Camaro 2SS Join Date: Feb 2015
No endplay clearance.
#4 | |
![]() Drives: 2010 Camaro 2SS RS Join Date: Jul 2021
Unless what your talking about is once you torqued the cam gear on the the camshaft the gear is not turning even without the chain on it. Then I would recommend checking the lifters, cam gear, camshaft thrust plate, amongst other things. Take your freaking time! The world will not end in a couple more hours that it take to go over things. I may be stupid, but It sounds like your guy may have forgot to reinstall the camshaft thrust plate. Make damn SURE he has a brand spanking new one, because those bad boys can, will, and surely fail. Anyway, just my $0.02 |
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Also, you have to make sure you get the correct one when buying. Some LS's used the regular style bolts and some used the countersunk bolts. The plate will be different for each type of course.
| Tags |
| broken, cam, lifters, not turning, wear |
