![]() Drives: 2013 Camaro SS 6 Speed Join Date: Sep 2021
Oil all over my diff and rear bumper!!!!
I was driving in the freeway and i thought it was my tire that popped. When i get out i see oil splattered on the back of my car. I slowly drove home but clanking went away but under the car, i saw there was a bunch of oil around the diff. Now when I drive there's this sort of humming sound. Can anybody help please. No oil leaking now
![]() ![]() ![]() ![]() Drives: 2011ss/rs camaro Join Date: Sep 2011
Check the level. There may be none to leak.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Time for a rebuild of the rear end, hopefully not too much damage but you will definitely need to get that diff apart and see what's going on
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
Banned
Drives: 2010 LS Join Date: Feb 2021
The axle seals leak after a while, or you changed the fluid and put synthetic in.
There is a TSB for certain year axle seals needing changed after changing the DIFF fluid with 100% synthetic. My driver side axle seal is leaking, a little, but it just whips on the side for now. If yours is all over the place, then look for cracks or hole from damage. Check the axle seals, there will be oil on the side or sides. Can also be the cover gasket, but the seals go first. The noise will be from no to low gear oil. |
Banned
Drives: Camaro 1LE Join Date: May 2018
Sound like you possibly need the rear diff repaired like immediately
| Tags |
| camaro, mechanic, oil leak, pop, problems |
