Old 09-09-2021, 09:39 AM   #1
TastyBake
TastyBake's Avatar
Drives: 2011 Camaro 2LT/RS Black
Post GM's CAI is the same as Cold Air Inductions CAI?
While researching something else, I stumbled upon this.
GM has a CAI for sale and it looks identical to Cold Air Inductions CAI, just without the label and a different color filter.
GM CAI:
https://www.gmpartsstore.com/oem-par...e-kit-84531831
Cold Air Inductions:
https://www.coldairinductions.com/sh...r-intake-black
Based on the price difference, I originally guessed CAI just wholesaled it to GM and GM is just a reseller, which happens all the time but just double checking if CAI knows about this.
TastyBake is offline   Reply With Quote
Old 09-09-2021, 03:12 PM   #2
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Isn’t that for a 6th gen? I believe CAI did work a deal with GM on the 6th gen.
Check out my build thread
Old 09-09-2021, 10:50 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Correct. that's a 6th gen CAI.
Old 09-15-2021, 01:17 PM   #4
TastyBake
TastyBake's Avatar
I see.
Thanks,
Old 09-16-2021, 07:21 AM   #5
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
K&N designed the one for the fifth gens, it’s standard on all Z/28s and is the GM performance CAI for the fifth gens.
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported 821 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, DSX aux pump, zl1 in tank. deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 09-16-2021, 08:31 AM   #6
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Interestingly enough, for the 2015 IMSA Continental Tire Series, the Camaro teams were instructed by Chevrolet Racing to switch to CAI, Inc. Stephenson Motorsports won the championship that season.
cai, cold air induction
