Old 09-10-2021, 03:59 PM   #1
diablo0730
Drives: 2015 Camaro 1LE
2015 1LE Not wanting to start after a drive.
So im having an issue of not starting after a drive it turns over slow and doesnt want to kick over. If it sets for 5 mins it starts up but kind of slow. Its also charging non stop at 14v with a new battery. When the engine is running its running strong. Is this the dreaded ground issue or something else dealing with electrical like the classic starter getting to hot and needs a better ground? Also it will start up pretty easy with a jump.
2015 1SS 1LE: BTR Stage 5 N/A cam, 1 7/8 Longtube headers, catless connectors, Z/28 Cold Air Intake, Vararam Power Wedge.
Upcoming Mods:
GPI Ported heads
GPI Ported Rodmod intake
ZL1 Injectors
DSX E-85 Flex Fuel Kit
diablo0730 is offline   Reply With Quote
Old 09-10-2021, 04:30 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Sounds like classic ground and/or starter issues.
Old 09-10-2021, 05:33 PM   #3
diablo0730
Thats what I figured after it set for like an hour and started up faster still slow but its also 106* at fort irwin, ca today. I ordered the ground wire from DIY already looking at new starters now.
Upcoming Mods:
GPI Ported heads
ZL1 Injectors
Old 09-10-2021, 05:41 PM   #4
cmack
Drives: 2011 Camaro SS
Buy the powermaster 9509 starter. I had ton of trouble and the starter was worth the money. It is gear reduction starter the engine turns over much easier now. Search forum and read up on this starter.
cmack is offline   Reply With Quote
Old 09-10-2021, 08:30 PM   #5
diablo0730
Awesome ill order one tonight. I just went down after its been sitting for about 3 hours and it started faster than my Hellcat lol. So its definitely heat soaked starter.
Upcoming Mods:
GPI Ported heads
ZL1 Injectors
Old 09-10-2021, 09:21 PM   #6
larry_g
larry_g's Avatar
This
Old 09-16-2021, 11:53 PM   #7
diablo0730
By far the best advise ive been given for a 5th gen haha. It starts up just as fast if not faster than brand new Camaros. Did it and the ground cable from Gen5 DIY.
Upcoming Mods:
GPI Ported heads
ZL1 Injectors
alternator, battery, cam, no start, starter
