Old 09-13-2021, 12:14 PM   #1
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Low oil pressure again
Hey guys I'm kinda down kinda pissed. As the title says I have low oil pressure again. I was on my way to the tuner yesterday to get an updated tranny tune and looked down at the gauges and noticed I was at roughly 15 psi at the stop light. So I went ahead and went to the tuner and noticed the lifters sounded louder then usual. So I got my new tranny tune from the tuner and drove home and also noticed my high pressure of 50 psi at cruising was now at 30 psi. So here I am at home all depressed so I changed my oil. Nothing in the oil so that's good. So I went on a test drive today and all of the sudden my oil pressure was back. So I pull over to change my tune on the tranny a little turn the car off and then restarted it with the new tranny tune and my oil pressure was back to 15 psi again at idle and 30 psi at cruising. So I don't know what to think. Is the oil pressure relief valve in the pump going screwy or what? Also I have the melling 10355hv pump. Any ideas?
Joe
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 09-13-2021, 12:20 PM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Can the sensor be going bad on you?
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 09-13-2021, 12:27 PM   #3
morepowerjoe
No I actually checked it via obd with hp tuners it was at 15 psi. I had a prior data log that I looked at before this happened and I had 34 psi at idle. Plus my lifters are louder.
Old 09-13-2021, 12:38 PM   #4
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Hptuners just uses the signal from the same sensor.
joshnmn is offline   Reply With Quote
Old 09-13-2021, 12:44 PM   #5
morepowerjoe
Oh yeah. Don't know what I was thinking. lol. But my lifters are a little more noisy. Maybe I should change the sensor though. I've heard it's a real pain though.
Old 09-13-2021, 12:56 PM   #6
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
It takes a little patience but can be done without removing the intake. Good luck.
HOJO is offline   Reply With Quote
Old 09-13-2021, 01:19 PM   #7
morepowerjoe
How likely is it that the sensor is really bad? Because it still works with increased rpm. I don't know how many post I've read where people have thought that was the issue and had the stealer replace it and still had an issue after wards.
Old 09-13-2021, 02:08 PM   #8
gtstorey
Time to check it with a mechanical gauge, although I have no idea what that will take.
Old 09-13-2021, 02:27 PM   #9
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
As mentioned ...
Check the pressure with a mechanical gauge and you are clear. If the pressure is OK, you probably have either a clogged sensor or it is damaged.
If the pressure is low, it will need to replace the oil pump.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 09-13-2021, 02:32 PM   #10
morepowerjoe
Has anyone ever used the oil galley plug on the front drivers side of the block to test for oil pressure? It's a direct feed from the oil pump, that should tell me right?
Old 09-13-2021, 03:01 PM   #11
George-CZ
George-CZ's Avatar
I would use the input directly for the sensor.
The information being compared will not be skewed.
Old 09-13-2021, 03:44 PM   #12
InFiD3ViL
InFiD3ViL's Avatar
Its really not bad man. If you have taken your intake manifold off before then that's about the extent of it. Can be done in an hour or less.
You can try to do it without removing the intake, but its a PITA and will leave you with a cut up hand and lots of cursing lol. If you have big hands don't even bother.
Old 09-13-2021, 03:55 PM   #13
morepowerjoe
Thanks bro.
Old 09-13-2021, 10:20 PM   #14
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
I have used the galley plug at the front drivers side of the block, and yes, it will give a direct reading of pressure from the pump. I'd check it at both places, personally, so you have a clear picture of what exactly is what and where.
I used a cheap mechanical gauge from AutoZone/Advance/etc., and drilled and tapped an old oil galley plug to accept the 1/8"-NPT mechanical gauge fitting. If you go that route, it will fit in both locations FYI.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
