NightFuryCamaro
Drives: 2012 Camaro 2SS Join Date: Aug 2019
I'm currently in the market for a better serpentine belt as the Whipple provided belt stretches a lot, and that is alarming. I'm not sure the belt I should be using as Gates neglects to post their belt size specs and only gives it in their part number codes, that most people (including myself) don't know how to read. Please help me determine the belt I'll need for my stock 6 rib setup!
Do note I run a Griptec 4.00 pulley and a fluidampr harmonic balancer that is also stock size.
Follow me on Instagram and TikTok! @NightFuryCamaro
https://www.instagram.com/nightfurycamaro/ https://www.tiktok.com/@nightfurycamaro |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Here's a chart...https://www.wanderlodgeownersgroup.c...20Listings.pdf Use K06 for 6 rib.
I ended up buying several progressively smaller belts from an auto parts store until I found one that was hard to get on (K060910). Once you have that number, you can add an "HD" to the end for their Heavy Duty belt or "RPM" for the Race Performance Muscle. I ordered a K060910RPM belt from RockAuto ($50.79 plus tax & shipping) and it should arrive today. Not sure when I'll have a chance to install it but I will create a thread when I do. I am running a 3.75 pulley so the K060910 should be too short for you.
| Tags |
| belt replacement, serpentine belt, supercharger, whipple 2.9 |
