Old 09-14-2021, 10:08 AM   #1
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
rotor thickness specs
Anyone have the specs for rotor thickness (stock GM)? I want to put a caliper on mine and see if they're worth resurfacing. Would like to know original thickness as well as minimum. Looking around here, I thought I saw 32mm as minimum, but want to confirm that and what's full size.
This is an SS, btw.
SS_Dave is offline   Reply With Quote
Old 09-14-2021, 10:40 AM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
This might help. Says nominal is 27.9 mm an discard is 26 mm.
https://www.rockauto.com/en/moreinfo...t=1896&jsn=490
Orange Krush II
Old 09-14-2021, 10:51 AM   #3
SS_Dave
SS_Dave's Avatar
Ah. Thanks. ok. Quick check on my crappiest one is around 28.5. And it's wavy, so resurfacing will take of a fair amount. Seems likely time to dump these and put on some good stuff.
