Old 09-14-2021, 09:32 PM   #1
LiveWireXIII
LiveWireXIII's Avatar
Drives: 2014 Chevrolet Camaro 2LS
Exclamation Hyperflash issue 6th gen headlights and taillights
Hey guys, looking for some help. I’ve got the Vland 6th gen headlights and taillights with Vland Led D2H low beam/high beam LED bulbs. I’ve got a hyper flash issue on the left side. The 6th gen headlight housing and 6th gen taillights both say no added resistors needed and led headlight bulbs have drivers in them as well. Both appear to have built in resistors and no bulbs are out, but why am I still getting hyper flash? I am not getting any error messages on the dash either. It just flashes 2-3 times normally and then goes straight into hyperflash non stop. Would new LED headlight bulbs fix? They’ve worked for a year and a half now and only just started doing t
Last edited by LiveWireXIII; 09-14-2021 at 09:34 PM. Reason: Uploaded 2 of the same photo by accident
LiveWireXIII is offline   Reply With Quote
Old 09-30-2021, 08:05 AM   #2
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Any luck with this? Hero states this may be an issue with their tail lights if LED Side marker lights are used. I have not installed mine yet but hoping that I don't run into this. The resistor that's built in could have gone bad.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 10-11-2021, 04:27 PM   #3
LiveWireXIII
I have not been able to fix it yet. The side marker lights are working as well as all the tail lights and DRL/headlights and brights. The fuses all look good, and the BCM is fine as well as all the wiring. It’s hard to tell if it’s the headlights causing it or the taillights but either way it must be a resistor because it works fine when you first start the car running 14.7 volts but as soon as it drops after driving boom hyperflash only on driver side. If it’s the taillights I would be somewhat relieved because they are so much easier to replace than the headlights. So if the hero taillights resistor goes bad they are pretty much done for?
Old 10-11-2021, 04:27 PM   #4
LiveWireXIII
I forgot to mention my side marker lights are stock still
Old 10-11-2021, 06:56 PM   #5
Joe.G
Joe.G's Avatar
I honestly don't know but I am assuming you could add one in line.
Old 10-13-2021, 06:45 PM   #6
LiveWireXIII
I’m going to plug in the factory turn signal bulb in the front this weekend and see if It works fine. Right now just focusing figuring out if it’s coming from front or back. All the small shops around here charge about 120 an hour for an electrical specialist to come in and diagnose so I’m trying to save money but it’s hard to figure out
headlights, hyperflash, rapidflash, taillights, vland
