Old 09-15-2021, 12:58 AM   #1
diablo0730
Drives: 2015 Camaro 1LE
Another ticking LS3 but doesnt sound like normal tick.
So ive been hearing this ticking sound from my Camaro since doing my cam swap and I can not figure it out. I vant hear it outside of the car but mainly when im inside the car. Its not exhaust leak i checked everything 4 times, checked rocker arms over and over, lifters are new, trays are new did the Trunnion upgrade as well. As the rpms go it it gets to sounding like a buzzing sound then the exhaust is to loud to hear it. Oil pressure is perfect and im stumped on this one. Are the OEM lifters not enough for the size of the cam?
I uploaded a video cruising back home from the store at about 15-1600rpm had to turn off radio and AC to hear it. Anyone have any idea? No codes are thrown and it still runs and drive fine.
https://youtu.be/U5Pw4OAMaOo
2015 1SS 1LE: BTR Stage 5 N/A cam, 1 7/8 Longtube headers, catless connectors, Z/28 Cold Air Intake, Vararam Power Wedge.
Upcoming Mods:
GPI Ported heads
GPI Ported Rodmod intake
ZL1 Injectors
DSX E-85 Flex Fuel Kit
diablo0730 is offline   Reply With Quote
Old 09-15-2021, 09:49 AM   #2
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Correct push rod length? Head gasket thickness? Are the new lifters different?
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 09-15-2021, 10:28 AM   #3
diablo0730
7.425 length which is correct for the cam i have. Lifters are all the same, headgaskets are LS9 so 0.055.
Upcoming Mods:
GPI Ported heads
ZL1 Injectors
Old 09-15-2021, 11:18 AM   #4
gtstorey
The pushrod length is only correct if you measured length needed to confirm.
Old 09-15-2021, 11:29 AM   #5
diablo0730
Push rods are the correct length. I double checked before i bought them.
Upcoming Mods:
GPI Ported heads
ZL1 Injectors
Old 09-15-2021, 12:11 PM   #6
gtstorey
Did you measure them or did you doubled checked what it was supposed to need based upon the cam?
Old 09-15-2021, 06:34 PM   #7
diablo0730
If i double checked it means i measured them if youre going to keep saying the same crap do it somewhere else.
Upcoming Mods:
GPI Ported heads
ZL1 Injectors
Old 09-15-2021, 07:08 PM   #8
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
But that's not what you said. I wouldn't assume you saying double checked means that you measured, but that you double checked the measurment of the part in question before you purchased it. Read what you said. When you're vague on what you're talking about it makes it difficult to help.
Do you have more details on what exactly you have done?
More to come.
Black_SS10 is offline   Reply With Quote
Old 09-15-2021, 07:52 PM   #9
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
I think he was just trying to clarify that you did measure no need to get nasty.
Sounds like a lifter tick, the only way I got mine to be quiet is to get pushrods that put the lifter piston way down in the lifter, about .030 to .050 from the bottom so about .125 to .150 preload. Also it helped when I ran thicker oil, now my valvetrain is really quiet and it still runs great after 15K miles with cam. Run high zinc oil too it helps make high performance valvetrains live.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 09-17-2021, 12:53 PM   #10
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I would never recommend running a thicker oil to quiet a valvetrain down. sacrificing your bearings for quiet valve train is not a good sacrifice to make. I am on the stock lifters and don't have an issue. I haven't gotten a change to listen to the link yet though. Mine has some valvetrain noise not really ticking just sewing machine type noise as the rpms go up. Be sure the exhaust or something is not hitting anywhere.
Greenhornet2 is offline   Reply With Quote
Old 09-17-2021, 01:07 PM   #11
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I don't think that I would have put regular old oem lifters with that cam. It's a bit much for them.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 09-20-2021, 07:38 PM   #12
Black_SS10
SomeguyK
Black_SS10's Avatar
Why do you say that? I've ran OEM lifters on big cams across many platforms with zero issues. It is all about setup and the RPMs they are going to be exposed too.
More to come.
Old 09-21-2021, 12:16 AM   #13
morepowerjoe
I just think if your going to spend all that money on a cam and other parts it probably good idea to upgrade your lifters while your in there for piece of mind.
Old 09-21-2021, 04:42 PM   #14
zz430camaro
Drives: 2015 1LE
I have run 20w50 royal purple for almost 20k miles and the engine is happy, oil pressure is always the same. The no thick oil in a LS is an unproven myth, in the summer is works just fine. I would say a sewing machine sound is not good it means metal to metal contact.
cammed, damage, lifter, swap, ticking
