![]() ![]() Drives: 2010 Camaro 1SS (BLACK) Join Date: Jan 2010
Diablo sport predator 1
Wanted to know if anyone knows about the first Diablo predator. Are they able to relearn idle?
Banned
Drives: 2010 LS Join Date: Feb 2021
YOU can relearn idle, there is no tool for that, and a tuner won't do it. All a scan
tool would do is allow you to move the throttle. Idle is learned on its own when you reconnect the battery. When you turn the car to ON/RUN the throttle will sweep from open to closed. SO, after pulling power, then back, turn the car on/run and wait about 15 seconds. Then start the car and let it idle for 3 minutes. Put it in gear, then let it idle some more. You will get a CODE for idle not learned if it does NOT learn do to an obstruction or actuator failure. |
