Old 09-18-2021, 09:29 PM   #1
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
Brake rotor options (less weight)
Hello,
Just wondering if anybody recommends a lighter brake rotors for the Gen5 SS ?
For the street.Want to keep the factory SS Brembo calipers.
I do have some ZL1 brakes here at the shop.Will check the weight difference.But I want to still be able to use my 17” Weld wheels (front & rear).Not sure if the factory ZL1 fronts work with 17” Welds because it a slightly bigger rotor and 6 piston caliper.Will have to test fit them I guess or if somebody can confirm it.
Just looking at options to loose a little weight here and there but also be good for daily use and be able to stop decent at a high rate of speed.
Thank you
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
