Old 09-20-2021, 06:41 PM   #1
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
Rear knuckle question
What is the part number for the upper control arm bushing on the knuckle? I have looked and found no clear answer. Or what is the best upgrade for the knuckle bushings?
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported 821 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, DSX aux pump, zl1 in tank. deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 09-20-2021, 07:04 PM   #2
gtstorey
I don’t think that is considered a serviceable item by GM. Don’t know about the aftermarket. I replaced my knuckles with Z28.
Old 09-20-2021, 07:32 PM   #3
Ashen L99
Ashen L99's Avatar
Yeah the whole knuckle is only 110 bucks for the SS. The Z 28 ones are discontinued, what else is out there after market?
Old 09-21-2021, 07:56 AM   #4
Scotty D
Drives: 2014 1le 1SS CRMT
I did the Z28 knuckles.
I was told i got the last right side in the country
Just replace your bushings with BMR ones you’ll be good
Scotty D is offline   Reply With Quote
Old 09-22-2021, 02:53 AM   #5
AlanRubin
Banned
Drives: 2010 LS
The UPPER and LOWER bushings in the Knuckle are SPHERICAL bushings. There
are no replacements, unless you have a 16+, and they're $500+ for the set.
There is a thread on this already, I am not typing it all in again...
Those bushings help retain camber angles with cornering. If you can find any POLY
or RUBBER replacement, it will work, but you will feel the difference. Also the
UCA inner bushings is also Spherical, and there is a POLY replacement for that.
AlanRubin is offline   Reply With Quote
Old 09-23-2021, 11:08 AM   #6
Ashen L99
Ashen L99's Avatar
Gotcha, I’m just going to order new knuckles.
Old 09-23-2021, 11:31 AM   #7
gtstorey
I think the part about spherical bushings is only for the Z28 knuckles.
Old 09-25-2021, 03:19 AM   #8
AlanRubin
Banned
Drives: 2010 LS
You think wrong there guy... They're all the same.
I have a V6, and they're spherical, and so is the inner UCA.
I mean, you can SEE the difference, and you can pivot the spherical ones
with your hands!
If you can't see the difference, well, then good luck to ya...
ALL the Gen5s have them in the same spots. They are in the knuckle
specifically for wheel track; to keep the most tire on the ground
under all conditions.
