![]() Drives: 2010 camaro ss white Join Date: Jun 2019
gpi stage 1 vvt idle at
Hey everyone, I have a question about where everyone is having there idle set to after a cam is done, my first tune it was set at about 675, the chop was awesome, Had a new tune done by new shop and now the idle is at 800 not as much chop now but the car is smooth and runs awesome, I miss the chop
thks Coop |
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
It’s a stage one so it shouldn’t chop much and around 800 seems right for it. Most people here with bigger cams have there’s set at 1,000
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
![]() Drives: 2010 Camaro SS Join Date: Oct 2020
Mine is a SS2 and it's set at 800 and it chops pretty hard. However they should be able to dial it down when in Park and Nutral if you want it to chop a bit more. Especially if you're not out racing folks.
Mine idles closer to 1K when 8n drive. I am an auto tho not sure what you can do with a manual.... Sent from my SM-F916U using Tapatalk |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
You can also add and take away chop in the tune. I can make a stock cam chop by messing with the timing. Just wanted to point out that it is not always about idle rpm or the physical cam specs that affect chop.
More to come. |
#6 |
thks everyone, i'm on the fence about having idle turn back down, that gpi chop is awesome, mine is a auto, slp super charger 8lbs boost, headers, flow master exhaust, 373 gears, ZL1 pump and msd boost pump 60lb injectors 611/628 it made on dyno, e85 coming soon ty
#7 |
SomeguyK
Lol Yup. Super popular with the mustang crowd.
More to come. |
#8 |
#9 |
I have a TSP Stage 3 cam and am an auto and the idle is set at 850 when warned up. 1000-1100 at cold startup. Badnasty.. lol
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I've been messing around with my tune and have mine set to 750 rpm when fully warmed up and that's with the SS1 vvt cam from GPI. I have a pretty big chop but my tuner set it up that way.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
#11 |
Sounds good!!
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
While not VVT, my GPI SS1 LS3 version has the idle set right around 800. She chops like crazy
#13 |
#teamGPI
Drives: 2010 Camaro SS Join Date: Aug 2020
My SS1 vvt is set at 850, warm idle
https://youtube.com/shorts/l5oH6owHmjQ?feature=share |
#14 |
those sound awesome, i want my chop back lol
