Old 09-20-2021, 10:34 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
Driveshaft/axles.
Should I upgrade my driveshaft/axles on a 1000-1200whp street duty car?
Car will be used for roll racing, and maybe Mexico… NO launching.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 09-20-2021, 11:01 PM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
I would keep the factory 2pc driveshaft. It has a higher critical speed and thus safer at higher rpms. I kept mine.
I would also keep the stock axles. Roll racing doesn't break axles. Dig racing and wheel hop does. Plus axles are cheap compard to grenading a trans or diff.
More to come.
Black_SS10 is offline   Reply With Quote
Old 09-20-2021, 11:11 PM   #3
RupertPupkin
That’s what I was thinking since the drive lines not trying to move this fat pig from a dead stop.
730whp: 630Trq
Old 09-21-2021, 07:43 AM   #4
fz4k98
Drives: 2013 1ss
tire choice will be a big factor. If tires are spinning they are also limiting the stress on the driveline. I didnt have driveline issues until i started running street slicks.
fz4k98 is offline   Reply With Quote
Old 09-21-2021, 09:09 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I gave my stock DS everything it had with no issues. I would stick with stock axles as long as you have the stock carrier. Let those break before you destroy the diff. If you go up to a TruTrac, 1000hp or Renegades would be my choice.
