Old 09-20-2021, 11:39 PM   #1
Flaco723
Drives: 2010 Camaro RS FBO
No Start Condition
Ok. So on my 2010 lately it will not crank and it shows 0 miles. Replaced the BCM with no luck. New bcm has also been programmed with my VIN. Sometimes it randomly shows the miles then cranks and drives as normal. But the dash is lit up like Christmas. Gauges work and all. But if I disconnect the battery it goes back to showing no miles and not cranking with the dead gauges. Even tried a new cluster. I’m at a loss here guys. One mechanic suggested the ECM may be faulty.
The only codes I’m getting are the 420 and 430 for my long tubes
Flaco723 is offline   Reply With Quote
