Old 09-22-2021, 09:40 PM   #1
DeathwishSS
Drives: 2014 2SS/RS
Problems after turbo install
I'm not sure this is the correct place to post this sorry in advance if wrong. I've installed the Huron Single kit on my 14SS and the squash dual pump kit with 1300cc FIC injectors. and I cannot figure out for the life of me what the problem is. originally there was a exhaust leak Pre O2 which I have since fixed but now it is pulling lean codes for both banks. My gauge is telling me I'm pulling 18"hg which leads me to think its not a vacuum leak. It still has the stock cam. Another thing I have going on is the car will idle after going into closed loop but, when I give it any throttle and let off it dies. I think it would be tune related but I am not sure. Any advice is appreciated thank you!
DeathwishSS is offline   Reply With Quote
Old 09-30-2021, 09:31 PM   #2
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Interesting
Has the tune changed at all since the install? It should be blubbery rich with the new fuel setup. Are you sure all plugs are firing?
(Btw, there are helpful people in this arena, but up a couple more there is a Forced induction thread)
joshnmn is offline   Reply With Quote
