Old 09-23-2021, 05:38 PM   #1
KevinHoward8509
Drives: 2014 camaro ss 1LE
Best twin turbo kit
Was looking into huron speed but checking to see opinions
Was looking at oil less twin 68s shooting for avout 1300 wheel
Opinions on the kit or a better kit out there?
2014 SS 1LE summit white
RWHP 1032
Modifications are as follows:
Engine, forged and stroked 416 CI, Procharger F1A-94 with upgraded race intercooler and big red blow off valve, HP Tuner, AEM Wideband with Gauge, TSP Supercharger Camshaft 224/240 .615/.615 112 +3, Brian Tooley Dual Valve Springs, Brian Tooley Chromoly Pushrods and ported heads. Fore innovations twin 450 pumps on E-85
Brian Tooley Titanium Retainers, GM 3 Bolt Conversion, New GM Oil Pump, Injector Dynamics ID 1700 Injectors, Kooks 1 7/8" Long Tube Headers ,
KevinHoward8509 is offline   Reply With Quote
Old 09-23-2021, 06:08 PM   #2
RupertPupkin
Drives: 2014 Camaro SS 1Le
AGP.. you can get their packaged options like box 1, 2, 3 etc, and just source out your own oil-less turbo.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 09-23-2021, 07:56 PM   #3
Omega
Drives: G8
FYI, the AGP hot side is good for 1k+, but the cold side will need their upgraded merge pipe. Fit and finish is great, I haven't heard the same about some of the Huron kits. I do have the Huron headers and they are well made.
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 09-23-2021, 08:33 PM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
AGP is a great kit. Fits good. Fairly easy to install. I just installed a twin 62/62 kit.
More to come.
Black_SS10 is offline   Reply With Quote
Old 09-23-2021, 09:10 PM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Never seen an AGP kit in person. I have a Huron single and have seen them on 4th gens, fox bodies, trucks and others. They’re well built and fit well also. No complaints
joshnmn is offline   Reply With Quote
Old 09-24-2021, 06:19 AM   #6
KevinHoward8509
Ill check out AGP. Appreciate everyones input. The shop doing it wasnt super crazy about the hron speed location for the twins but also knows room is limjted haha.
RWHP 1032
Old 09-24-2021, 11:41 AM   #7
AGP Turbo
Drives: All things Turbocharged
Before you get too excited about oil less turbos. Try and find someone not affiliated with Comp who has ever got 20,000 miles out of one. Usually dead by 5,000. It might be super cool technology someday, but is totally unreliable right now. Regular oiled turbos usually last over 100,000 miles.
AGP Turbo is offline   Reply With Quote
Old 09-24-2021, 01:28 PM   #8
KevinHoward8509
i agree 100% me and the shop i go to have been talking about this non stop haha. we also are struggling with how well they legit perform being they are a greased application and with grease being such a heavy weight whats the true performance of these. seems like that grease would drag the RPM's down on the impeller.
Right now we are looking at the AGP kit with G35 garrets.
RWHP 1032
Old 09-25-2021, 03:43 PM   #9
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
I'm happy with the AGP. 4+ years.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 09-25-2021, 05:09 PM   #10
KevinHoward8509
What turbos did you go with? Fitment of the kit was no issue? What manifolds did you use?
RWHP 1032
Old 09-26-2021, 09:14 AM   #11
JMI
JMI's Avatar
AGP 62mm ,regular AGP plenum with ARH shorty because I now have 6 bolt heads & block Would have loved to keep the manifolds for easier access for the spark plugs & wires,but it's not too bad.I ran the manifolds when I was running the original engine and heads which I still have in a crate if needed.No fitment issues.Think I was the second AGP kit that got shipped to Canada when they came out.
Old 10-01-2021, 09:22 AM   #12
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
4 options I can think of off the top of my head:
AGP - No experience, but I always here good things about these kits. The only downside from my perspective is they are limited to a T3 turbo.
Huron - I have this kit and have been happy with it thus far. Had to grind on the compressor housing to clear the driver's framerail and grind on the passenger turbine housing to clear the hotside piping so the turbo could bolt up properly. Overall, happy with the kit. It comes standard with T4 flange. You can search for my threads to see my build.
Hellion - no experience... but it is a high mount kit and will surely generate a ton of heat in the engine bay.
UPP - no experience... but it is a high mount kit and will surely generate a ton of heat in the engine bay.
RealQuick is offline   Reply With Quote
Old 11-13-2021, 11:59 AM   #13
K8811ss
Drives: RS/2SS white/black
I had the UPP kit on my stock Ls3 for 5 years with no problems. It got a little hot but heat soak wasn't really an issue.
UPP 58mm TT, 127lb per hr. Injectors, e85 flex fuel w/ duel Areomotive fuel pumps, TSP stage 3 blower cam 900+hp 9.5psi
K8811ss is offline   Reply With Quote
Old 11-16-2021, 01:32 AM   #14
Rem0v3r
Drives: 2013 ss2 vert l99
For 1300 wheel (youre going to need fully build engine and driveline). Id go with a custom hotside big single 88.
Rem0v3r is offline   Reply With Quote
