Old 09-26-2021, 11:30 PM   #1
dma05
dma05's Avatar
Drives: 2011 Camaro 2SS/RS
Goodridge - Rears don’t fit
Went to install my new lines today, but the rear lines won’t fit through the bracket that has the one flat side on it. It’s too large and will not go through. Is this a known issue or did the packaging at the manufacture get messed up. The part number on the box is correct: 12219
I ordered them through Phastek.
Thanks
Allen
2011 Camaro 2SS/RS
dma05 is offline   Reply With Quote
Old 09-27-2021, 08:21 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I used their 12227 kit when I switched to ZL1 brakes and the lines fit perfectly. A pic of the problem might help.
Old 09-27-2021, 11:07 AM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
An move to the suspension, chassis an steering might get you some more answers as well.
Orange Krush II
Old 09-27-2021, 11:31 AM   #4
dma05
dma05's Avatar
My bad. How do I move it? Or does an Admin need to do it?
Thanks
Allen
2011 Camaro 2SS/RS
Old 09-28-2021, 01:08 AM   #5
dma05
dma05's Avatar
I contacted Phastek who contacted Goodridge who then contacted me. It seems that it was a problem with packaging at the manufacturer. I will have an answer by tomorrow and hopefully a new set of lines on the way.
Allen
2011 Camaro 2SS/RS
