Old 09-27-2021, 06:04 PM   #1
BEECHFRONT
BEECHFRONT's Avatar
Drives: 2013-ZL1, 69-Z28, 71-CHEVELLE SS
2013 6sp manual zl1 vibration?
I am having a vibration or shudder problem that I cannot figure out.
When Im rowing through the gears winding it out there are no problems, when im just cruising 50 60 mph in 5th or 6th and step on it kinda lugging the engine the car starts to shake vibrate etc...Im sure the clutch is not slipping, this just happened all of a sudden, im stumped? Any idea what I should be looking for?
2017 C7 Z06
2013-ZL1
2017 HELLCAT SOLD
2019 HELLCAT REDEYE WB
69-Z28, LSA SWAP, T56 MAGNUM
71-CHEVELLE SS, 496 STROKER TH400
BEECHFRONT is offline   Reply With Quote
Old 09-27-2021, 07:27 PM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
The things I'd first look at is wheel balance and driveshaft.
JB'sZL1 is offline   Reply With Quote
Old 09-27-2021, 08:09 PM   #3
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Hard to say without more info but if the steering wheel shakes its front tires, rims rotors etc. if the car it’s self is shaking and it’s only upon acceleration I would check the driveshaft center bearing as it’s on a spring. Next would probably be a broke spring or springs on the clutch but you should hear a little rattle at idle if that’s the case. Any work done in the last 6 months?
ZMEnow is offline   Reply With Quote
Old 10-06-2021, 06:57 PM   #4
BEECHFRONT
BEECHFRONT's Avatar
This happen right after my battery was dead after sitting a few weeks ,maybe coincidental? So I check driveshaft, axles, etc... for any play everything seems fine.
seemed like it was a miss/shudder under load. put new plugs in and swapped out coils no change.
Now I noticed when I wind out the gears with pedal to the floor I can here a slight backfire out of the exhaust, sounds like ignition problem???
Car has 4k miles on mods , cam,injector,pully's,headers, dsx fuel etc... no problems untill I had to change out my battery.
2017 C7 Z06
2013-ZL1
2017 HELLCAT SOLD
Old 10-06-2021, 09:16 PM   #5
ZMEnow
Who installed the DSX fuel? How’s it wired.
Old 10-06-2021, 09:44 PM   #6
BEECHFRONT
BEECHFRONT's Avatar
Everything was done by complete street performance in west chester pa.
2017 C7 Z06
2013-ZL1
2017 HELLCAT SOLD
Old 10-06-2021, 10:03 PM   #7
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
I had something similar on my SS. Check and make sure the CV axles at the hubs are tight. My left rear loosened up on me and caused some weird vibrations occasionally. Re-tightened, and good to go.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 10-06-2021, 10:09 PM   #8
ZMEnow
I ask because initially you mention vibrations and I took that as non power plant, but if you think the motor is stumbling which I don’t know you experience but night in day from a suspension or drive train vibration. Some people use the the battery ground for BAP and DSX, and since you changed the battery you may need to check you did not disrupt a connection.
Old 10-21-2021, 07:41 PM   #9
BEECHFRONT
BEECHFRONT's Avatar
Fixed, Ended up being a bad plug wire.
Thanks
2017 C7 Z06
2013-ZL1
2017 HELLCAT SOLD
