Old 09-27-2021, 05:18 PM   #1
fireman1153
Drives: 2010 Camaro SS
Harness bar, harnesses, rear seat delete and shifter
I’ve got a few odd items that I need to part with. All items will fit 5th gen Camaros.
Harness bar - $600
Sparco 4 point harnesses, driver and passenger side (good through 2022) - $100
Combine harnesses and bar - $650
Rear seat delete - $200
Hurst shifter - $100
Harness bar and harnesses were only mounted and removed, never used in new condition. Shifter was ran on the car for about 2 years, roughly 25k miles.
2010 Camaro 2SS/RS - 416 stroker, F1A-94 procharger, BTR blower cam, Big Red race valve, AGP intercooler, Alky dual nozzle kit, ZL1 fuel pump with DSX Aux pump, DSX flex fuel sensor, Bosch 210 injectors, Mcleod RXT1200 clutch, MGW flat stick, Tick Performance Level 3 trans, DSS 3.5 aluminum driveshaft, Strange S60 rear, DSS 1400hp axles, Texas speed 1 7/8 headers, X-pipe and MBRP muffler delete, BMR lowering springs, BMR trailing arms and toe rods, Poly motor mounts, RevShift trans mount instert, rear sub frame braces, Tuned by Joey at Pure Fabrication in Panama City, FL
fireman1153 is offline   Reply With Quote
Old 09-27-2021, 06:02 PM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Location Florida
Booooooo
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 09-28-2021, 12:57 PM   #3
Army of Wuzzy
Army of Wuzzy's Avatar
Drives: 2011 Chevrolet Camaro LS
Where'd you get that seat delete?
"If you aren't first, you're last"
-Ricky Bobby
Army of Wuzzy is offline   Reply With Quote
Old 09-30-2021, 09:56 AM   #4
fireman1153
There's no markings on the delete but I believe it is an SMG kit. It was actually with the car when I purchased it but the guy had never installed it and I put the rear seat back in.
Old 10-03-2021, 03:18 PM   #5
fireman1153
Sold
Old 10-03-2021, 08:07 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
It’s all sold?
Orange Krush II
Old 10-03-2021, 11:34 PM   #7
fireman1153
Only thing left after tomorrow is the shifter.
