Old 09-27-2021, 07:32 PM   #1
DJ_BigC
Rockin' Steady
DJ_BigC's Avatar
Drives: 2010 Camaro 2SS
2010 SS 20x10 Square Set Up
Ladies, Gents.
I’m due for a new set of wheels on my car. (2010 SS with stock suspension and alignment angles) I’ve always liked to be able to rotate my tires for longevity reasons.
I found a set of wheels that I finally like.. they are listed as 20x10 +35 offset.
My question is with that offset all around can I run a 285/35ZR20 like the ZL1 fronts or will I have some rubbing issues with the front strut because of the offset. I have the ability to get a +25 offset aswell.. but I’d rather be square all around.
I’ve searched and found some conflicting answers. Some poeple are running 275’s all around, some are staggered, some are wider.. i just feel a 285 is the best tire for a 10”
wide rim.
Thanks!
Eric Carrier, proud GM Technician for over 10yrs.
2010 Camaro 2SS Black, L99, SLP headers, GMPP axle back, complete JRE tune, 22" Boss 337's, Nitto Invos 5% tint, Eforce Supercharger w. 3" pulley, ADM FPCM, ID850's, JRE fuel rail mod, Eforce CAI, Moroso catch can, spark plug insulators.
DJ_BigC is offline   Reply With Quote
Old 09-27-2021, 10:03 PM   #2
Zombie killer
Emerald Coast Camaros
Zombie killer's Avatar
Drives: 2013 2SS/RS L99
You should be able to run the 285s but it will be close depending on tire you choose. Some run wide and some dont. I have run the same size and offset in the past but I also run a 4 mm front spacer up front with extended lug nuts installed. But I track my car and I don’t like sidewall flex to rub anything just in case. My pic is of the 285’s mounted for track days and daily use.
Edit: I run 20x10.5” wide rims and the ones you are looking at are 10” rims and they should be no problem.
Zombie killer is offline   Reply With Quote
