Old 10-02-2021, 11:38 AM   #1
DRG BSTN SQUIRREL
DRG BSTN SQUIRREL's Avatar
Drives: 2011 Camaro 2SS
Fuel question
Running out of fuel psi after 8 psi. I know I need to upgrade system but wondering if there is a simple way to do this vs $1k systems.
DRG BSTN SQUIRREL is offline   Reply With Quote
Old 10-02-2021, 12:01 PM   #2
fireman1153
Drives: 2010 Camaro SS
ZL1 fuel pump and boost a pump or just go DSX Aux pump if you don't want to dive into a whole new fuel system. However, the DSX Aux is still gonna run you $1K.
2010 Camaro 2SS/RS - 416 stroker, F1A-94 procharger, BTR blower cam, Big Red race valve, AGP intercooler, Alky dual nozzle kit, ZL1 fuel pump with DSX Aux pump, DSX flex fuel sensor, Bosch 210 injectors, Mcleod RXT1200 clutch, MGW flat stick, Tick Performance Level 3 trans, DSS 3.5 aluminum driveshaft, Strange S60 rear, DSS 1400hp axles, Texas speed 1 7/8 headers, X-pipe and MBRP muffler delete, BMR lowering springs, BMR trailing arms and toe rods, Poly motor mounts, RevShift trans mount instert, rear sub frame braces, Tuned by Joey at Pure Fabrication in Panama City, FL
fireman1153 is offline   Reply With Quote
Old 10-02-2021, 12:13 PM   #3
DRG BSTN SQUIRREL
If going to go do it all, should I keep 6an size or go up to 8an?
Old 10-02-2021, 12:19 PM   #4
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Simple or cheap?
Simple is pulling it into the local shop and tell them you’re running out of fuel, then hand them the keys and your checkbook.
Not much is cheap in the fuel arena
joshnmn is offline   Reply With Quote
Old 10-02-2021, 01:03 PM   #5
DRG BSTN SQUIRREL
Originally Posted by joshnmn View Post
Simple or cheap?
That’s no lie. I gotta get rid of the cats cause of heat soak and the off road mid pipes are no longer being sold. So now I gotta get a exhaust system too. I was just seeing if there was an alternative but my hopes are shattered.
Old 10-05-2021, 08:34 AM   #6
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Just gut the cats and leave the shells there. No need to cut them out and totally redo the exhaust.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 10-05-2021, 08:39 AM   #7
BiggFoot
BiggFoot's Avatar
Once upon a time I had an inline boost fuel pump that came on at WOT and it worked great up until I made the switch to E85 and had to totally redo the fuel system. It was set up that way when I bought the car from a guy in Chicago, and when my shop saw the setup they thought it was pretty slick. I think Chicago Speed did the install or maybe it was called Speed Inc.
https://www.speedinc.com/walbro-255l...-pump-kit.html
Blower Cam
RPM Level VII
TR6060
Old 10-05-2021, 03:12 PM   #8
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Really need more info on your build to give an accurate answer. JMS voltage booster if you don't have a BAP already. FPCM tuned already I hope?
Greenhornet2 is offline   Reply With Quote
Old 10-06-2021, 04:25 PM   #9
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
With fueling it always cost big bucks . Plus figuring doing it right the first time . To make sure my fuel is adequate for my build my fuel systems costing me somewhere 4500.00 ball park . That just for parts !! Injector , fuel system
, e85 sensor .
Risingson05 is offline   Reply With Quote
Old 10-07-2021, 07:12 AM   #10
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
When I put nitrous on, I put on a BAP that came on when when the nitrous was armed. When I added the turbo, I put in a ZL1 pump and FPCM and ran the BAP off a Hobbs switch. I got the BAP and pump off here for $100 each. That supports my power level fine, but I am getting close to the limit. If you buy those parts new, you are getting to a cost where you might just want to go to a bigger drop in pump. This is with the stock fuel lines and rails.
If you are running the stock pump, the ZL1 pump will take you to the 600hp range. A BAP alone probably gets you in the same power range.
If you are ever going to want to turn it up near 1000hp, just get a big pump and change the lines now.
Old 10-07-2021, 07:42 AM   #11
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
What are the ultimate HP goals... and what fuel? Running meth injection?
RealQuick is offline   Reply With Quote
Old 10-26-2021, 08:54 PM   #12
Rem0v3r
Drives: 2013 ss2 vert l99
When I switched to e I needed an aux pump.. got me to 15psi.. now I'd have been better off springing for the fore system.. but i didnt.. so rather than ditch my zl1 + aux.. im just going to add 8an fuel rails and a 2nd aux...
Rem0v3r is offline   Reply With Quote
