Old 10-09-2021, 09:20 AM   #1
GenesisCoupe
Drives: 2011 Chevy Camaro 2SS A/T
Question L99 Vibration in car
Good day. Does anybody have any vibration in car like a torque converter malfunction ? I visited GM service, they disabled turning off 4 cylinders and no vibrations at all. It very looks like torque converter issue. What engine parts may be needed for replacement ? Any suggestions
GenesisCoupe is offline   Reply With Quote
Old 10-09-2021, 04:13 PM   #2
xstuntman
Drives: 2012 Victory Red LFX
I think there was a TSB for the torque converter clutch regulator valve on the Camaros and some of Chevys other models. I know the vibration was common on the V8 trucks too.
Chevys AFM sure was a piece of crap for owners.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 10-09-2021, 05:12 PM   #3
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Time for a big cam and a stall converter
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 10-09-2021, 08:29 PM   #4
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
If no vibes with AFM/DOD disabled….Have it turned off permanently with a tune.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 10-10-2021, 02:55 AM   #5
GenesisCoupe
Question
i have written popcorn firmware, i should return to the stock one, then will check again. maybe system does not recognize what is going on.
What AFM/DOD consists of ? 4 electronic hydro compensators ?
Old 10-10-2021, 07:52 AM   #6
hunter1660
hunter1660's Avatar
Absolutely and It’s controlled by the ECM….save the popcorn for the movies and tune out the bad vibes
Old 10-11-2021, 05:10 AM   #7
GenesisCoupe
I returned back to stock firmware with no cat settings. The issue remains.
I went to the GM dealer. When AFM system is ON everything is OK. Vibrations and kicks happens while driving during changing from OFF to ON and conversely.
They said that the engine oil pressure on idle is 20 psi and this can be a reason. But GM dealer does not know what to do and how to solve this problem. Oil is 5W30, stock pump.
Any suggestions?
Old 10-11-2021, 11:00 PM   #8
GenesisCoupe
Found OBDII device on Amazon, Range Technology Plug & Play AFM/DFM Active Fuel Management Disabler Compatible with GM Vehicles RA003B.
Does anybody used this one ?
Old 10-12-2021, 05:07 PM   #9
truckertim
truckertim's Avatar
Drives: 2015 ss rs 2ss
I have this in my 2015 and have not had any issues just dont leave it plugged in it will drain battery.
truckertim is offline   Reply With Quote
Old 10-12-2021, 08:44 PM   #10
GenesisCoupe
Will it work with tuned ECU? I have O2 sensors disabled, settings were modified in the ECU...
Old 10-13-2021, 05:38 PM   #11
truckertim
truckertim's Avatar
That I dont know but its cheap enough to try and see.
Old 10-13-2021, 05:39 PM   #12
gtstorey
Why not get it turned off in the tune then?
Old 10-14-2021, 04:42 AM   #13
GenesisCoupe
In my country nobody could do this ) Range device is my option
Old 01-25-2022, 03:39 AM   #14
GenesisCoupe
Anybody could help with restoring DOD/AFM ? Its this kit (x2) is enough ?
https://www.ebay.com/itm/224342306459
