![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
For Sale: Vorshlag Camber Plates and BMR Rear Camber Bolts
SOLD!
Used Vorshlag Gen5 Camaro Camber Plates and New BMR Gen5 Camaro rear camber bolts The Vorshlag camber plates are in very good condition cosmetically, and the bearings are in excellent condition. After having owned three different manufacturers of camber plates, these are the most robust and quietest of them all. Unfortunately, I removed these after finding a set of new Moreno camber plates which would allow me to add both camber and caster. The Vorshlags only add camber. The top part is painted silver. For use with OE springs and they will add 1* of negative camber in addition to what you may gain at the strut/knuckle. $275 shipped https://vorshlag-store.com/collectio...nt=36262093831 BMR Camber Bolts, new never used, If you are looking to get aggressive with your rear camber these will get you the desired #s. Excellent condition, $65 shipped https://www.bmrsuspension.com/?page=...576&superpro=0 Thank You Chad
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather Last edited by cdb95z28; 10-12-2021 at 12:21 AM. Reason: SOLD! |
Does the camber plates change ride height?
Orange Krush II
![]() Drives: 2011 Chevrolet Camaro LS Join Date: Jun 2018
No it's not supposed to
"If you aren't first, you're last" -Ricky Bobby |
![]() Drives: 1997 Camaro SS Join Date: Jan 2010
PM sent
I did not have any ride height change with these Vorshlags. PM replied to.
"KEEP THE FAITH"-Fbodfather |
#6 |
Bolts and Camber Plates Sold! Thank You 2thousand2!
#7 |
