Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Suspension / Chassis / Brakes
Old 10-10-2021, 11:55 PM   #1
GforceJunkie
GforceJunkie's Avatar
Drives: 2010 SS Camaro
Item is no longer available
I have a customer that purchased a 2010 camaro and he wants the car quieter inside. One of the things he wants me to change are the solid rear cradle bushings. I have removed the bushings and I’m not sure of the brand. They came out pretty hard so there are some gouges from having to use a chisel but I don’t think their integrity has been impacted. They will need a little grinder work to clean up a few spots. I’m willing to trade the solid bushings for the stock bushing washers or cups so I can install the polyurethane bushings he has. I can send pictures if you’re interested.
Last edited by GforceJunkie; 10-13-2021 at 06:09 PM. Reason: Item is no longer available. Please delete
GforceJunkie is offline   Reply With Quote
Old 10-11-2021, 04:01 AM   #2
AlanRubin
Banned
Drives: 2010 LS
The BMR Poly bushings install in the hole by themselves, larger one on top, smaller
on the bottom. The only parts you need are the bottom metal washers from the original
factory bushings.
https://www.bmrsuspension.com/siteart/install/BK024.pdf
AlanRubin is offline   Reply With Quote
Old 10-11-2021, 07:04 AM   #3
GforceJunkie
Exactly, those are what I need. This car had solid bushings installed when my customer bought it so there are no bottom metal washers. I need the metal washers.
Old 10-11-2021, 11:00 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Those rear cradle bushing do not cause any noise I’d look at the diff or something else for the source of the noise.
Orange Krush II
Old 10-11-2021, 11:09 AM   #5
gtstorey
You may want to confirm that there aren't any bearing problems with the rear axles. I didn't find the solid bushings made a noise difference when I first installed them, but a wheel bearing going out, that didn't show up any other way, made it sound like the rear diff was eating itself.
Old 10-11-2021, 11:48 AM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Like these
Old 10-11-2021, 11:53 AM   #7
CamaroCracka
I saw the same thing. I put them in and got all kinds of vibration and it was a bad hub/bearing.
Old 10-11-2021, 11:58 AM   #8
GforceJunkie
Thanks for the suggestions about noise. I have solid bushings in my personal car and the road noise increased a little but I expected it. The chip seal roads here are loud to begin with. This is for a customer and he wants the neoprene bushings
rear cradle solid bushings, rear subframe solid bushings, solid bushings
