Old 10-11-2021, 12:33 PM   #1
Smokey_SS
Drives: Chevrolet Camaro
2011 Camaro Struts
Having an issue with my steering wheel shaking over 55 MPH and it gets worse as speed increases. I have replaced tires and basically everything in the front end. I was thinking maybe the struts up front went bad? I was looking to replace them and was wanting to know what brand everyone was using. If you have any insight what else could be causing the problem it would be appreciated. The car has headers ,CAI, E85, 1.25 lowering springs and a GPI Stage 3 cam. Thanks in advance.
Smokey_SS is offline   Reply With Quote
Old 10-11-2021, 01:07 PM   #2
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
what parts include "replaced basically everything in the front end".
Old 10-11-2021, 02:36 PM   #3
Smokey_SS
control arms, tie rods, rack and pinion. wheel hub
Old 10-11-2021, 03:40 PM   #4
ronwc
2011 Camaro RS conv
ronwc's Avatar
Drives: 2011 camaro rs
What about bent rim?
ronwc is offline   Reply With Quote
Old 10-11-2021, 03:43 PM   #5
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Look on the inside of your wheels & see if you lost any stick on weights.
acutron42 is offline   Reply With Quote
Old 10-11-2021, 03:44 PM   #6
gtstorey
Bilstein
Old 10-11-2021, 04:38 PM   #7
Smokey_SS
its gotten balanced 3 times. wouldnt they be able to tell from that?
Old 10-11-2021, 04:49 PM   #8
gtstorey
Not necessarily. They often don't look or care.
Jack a wheel and spin a tire while sliding a block of wood slowly toward it (both back and side. This will check for problems in the tire and rim. Then slide the block toward the rim while sitting on something so it can reach the rim to check the rim separately.
Old 10-11-2021, 07:02 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I replaced my front struts when it was time with the same OEM that was on it from the factory since they lasted so long.
Old 10-12-2021, 12:09 PM   #10
11-Camaro
Drives: 11 Camaro SS, Ninja 1000, Santa Fe
I had to do 4 visits to different locations for wheel weights. Hard to believe that level of incompetence but that was exactly what I had recently...
11 Camaro TT SS. 14 1LE motor, full coilover, CNC ported LSA heads, stainless valves, dual springs, Comp 224 cam, Melling oil pump, AGP Garrett GTX30r's, 1400cc injectors, full 3" Magnaflow, dual Walbro 450lph fuel pump, ZL1 6L90 trans, trans cooler, Circle-D 3600, 3.91:1 Eaton Truetrac, line lock, Lingenfelter 2 step. Current boost - e85 814 RWHP.
11-Camaro is offline   Reply With Quote
Old 10-12-2021, 05:52 PM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Wow, that's messed up!! But yea you gotta watch out for the "incompetence" places out there.
Old 10-12-2021, 11:44 PM   #12
AlanRubin
Banned
Drives: 2010 LS
Any suspension part that's bad will cause the wheel to shake. Sometimes only
when turning in certain directions.
My issue was the left side forward lower control am, they do have ball joints.
The issue arised once more last week, same side, was the TIE ROD END.
SO, take your pick.
Jack the front end up.
Grab each tire at 3 and 9, and wiggle it. If you have movement, it's the tie rod, or end.
If you have it at 6 and 12, it's an LCA, or loose bolts holding the strut to the knuckle.
IF you have movement at 10 and 4, 2 and 8, along with the others, it's a wheel
bearing.
AlanRubin is offline   Reply With Quote
Old 10-14-2021, 05:49 PM   #13
Royal Tiger
Drives: 2013 2SS/RS Convertible
Just to add to the replacement discussion, I was looking at the entry level Koni orange and one of the site sponsors was having a sale and I got Koni yellow for a few dollars more. Very happy with them.
Royal Tiger is offline   Reply With Quote
strut
