Xtreme Horsepower
Drives: Black 2010 SS Join Date: Aug 2009
AC belt tensioner??
Anybody noticed the lack of a AC belt tensioner. How do you expect to change the belt?
Good luck |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
I haven't looked yet, but is it the old fashioned method of loosening a bolt and repositioning the compressor and tightening the bolt?
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
Drives: Cargo van. Join Date: Jul 2009
Im not for certain on this, as what I heard came from the internets, but I heard they are one time use belts only and they stretch over the pullies. It sounds logical in the way that it looks like it could be done, and GM likes 1 time use parts.
![]() Drives: 2010 SS2/RS Victory Red Join Date: Jul 2009
You are correct.
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
Correct, one time use, you just have to rotate the pulley and spin the belt on and off. Unbelievable that GM couldn't put some sort of adjustment to the mounting of the AC compressor. Have you noticed how tight that belt is?
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
#6 |
![]() Drives: 2010 2SS - RS Join Date: Oct 2008
Yes, no belt adjustment on the a/c compressor. GM says to cut the belt when taking off the compressor. I have had 2 put on under warranty. GM list price on the "special belt" was $298 and it comes with an installation tool.
#7 |
I replaced mine when I did the Under drive pulley.. what a pain in the a$$.
and no loosing up the compressor doesn't make it any easier.. the frame rails get in the way, and you would have to totally disconnect the AC lines from the compressor to get it to go on.. only way to get it on is to do like what was mention.. start on one side, and rotate the crank pulley while guiding the belt into it's proper groves.. a real pain in the a$$
#8 |
![]() ![]() ![]() Drives: 2015 SS Sedan M6 Join Date: Dec 2009
GM ac belt = HomieMcWank, Johny Jerryrig, Darrell Dinkledoink, Do it McFly (pick one)
#9 |
Syntax Error
Has anyone cross-referenced the P/N on the belt to something we can pick up at the local parts store?
#10 |
Ghostly Unknown
Drives: Silver Ice 2010 SS/RS A6 Join Date: Oct 2008
I was told that snap-on has a tool that supposedly clamps on to the crank pulley and walks the belt on "EASILY"..Anybody know anything about it?
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
#11 |
Plays with Hot Wheels
Drives: '17 Jet Black ZL1 Join Date: Apr 2010
I was able to "walk" my original belt off and the shorter one on when I installed my U/D pulley. Not sure what all the fuss is about.....I didn't think it was that tough.
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring) |
#12 | |
http://www.gates.com/stretchfit/asse...v_brochure.pdf Gates P/N 91030
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
#13 |
Syntax Error
I purchased the belt from my dealership, came with the install tool and the belt cost somewhere around $45 with my discount.
#14 |
![]() Drives: 2010 2SS Join Date: Apr 2010
I installed the AC belt by holding (no special tool) it in place on the crank pulley and turned the engine with a socket and ratchet on the pulley bolt. I had the spark plugs out at the time, so it wasn't too bad.
| DIY : Install underdrive pulley on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 34 | 09-30-2013 09:25 PM |
| Seat belt not adjustable! | Temper | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 13 | 11-25-2009 09:28 AM |
| Safety Belt Audible Reminder System | Temper | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 16 | 11-14-2009 07:23 PM |
| Seat belt tension | BulletSS | 5th Gen Camaro SS LS LT General Discussions | 4 | 11-13-2009 12:19 PM |
| New & Stronger LSX belt tensioner now available from MTI Racing! | MTI Racing | V8 Bolt-Ons & Tunes | 2 | 05-28-2009 02:05 PM |
