Old 10-12-2021, 08:07 PM   #1
marathonmann
Drives: 2014 Camaro SS 1LE
2nd track day with the 1LE
Hey guys, just did my 2nd track day with my 2014 1LE and have a couple thoughts and questions. My car is stock suspension wise with long tube headers and a tune. I'm running Bridgestone RE71 tires (140 treadwear) The car was great for the most part with the exception of the brakes and a strange squealing sound that surfaced later in the day. The noise seemed to come on between 4500 and 5000 RPM when I was accelerating down the straight at full throttle. Almost sounded like brakes make when they are down to the wear indicators, but I was not on the brakes and the sound was not there when I was on the brakes. The other thing was after the 5th run, when I came in smoke was rolling off my front right rotor(obviously over heated the front brakes) I could see some scoring on the rotor. Any advice on what that noise could be and recommendations for a good rotor/pad upgrade would be appreciated. I'm not a track rat, just do a couple events per year and I did run with traction control and stability control off. Thanks !
marathonmann is offline   Reply With Quote
Old 10-12-2021, 10:15 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I bet it was the serpentine belt.
Orange Krush II
Old 10-12-2021, 10:24 PM   #3
marathonmann
Thanks, for that reply. That actually crossed my mind, could it just need tightening ? Car only has 14k miles on it, wouldn't think I'd need to replace it already
Old 10-13-2021, 12:32 AM   #4
shu92870
shu92870's Avatar
Check the pads too.
May be worn worn further then expected.
I wore my inner drivers side down past warning bar mark almost to the bracket/backing. Slight score on the rotor. I got lucky and heard it last 2 laps of 3rd session and shut it down loosing out last 2 sessions.
Pads were only 1 track day and like 1,500 street miles.
shu92870 is offline   Reply With Quote
Old 10-13-2021, 07:19 PM   #5
marathonmann
Thanks, what did you end up replacing them with ?
Old 10-14-2021, 01:20 AM   #6
shu92870
shu92870's Avatar
I ended up replacing with another set of the Brembo Ferodo HP1000.
But its time to upgrade.
Im ordering the Raybestos ST43 F & R for the track.
Ill use the Brembo Ferodo HP1000 for street.
I do like the Brembos.
Old 10-15-2021, 03:09 PM   #7
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
If your serious about tracking and braking power look into the ZL1 front brake upgrade.
There is a long thread on here about that.
Also brake ducts will help alot. If you can find a set of Z28 brake ducts that would help,
Brake fluid would be another suggestion.
You posted in the 1LE form which is a great place but you should check out the Road Race form as well.
Good luck and enjoy.
Craig
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 10-15-2021, 03:12 PM   #8
SS Performance
Check out this thread.
https://www.camaro5.com/forums/showthread.php?p=8744227
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2015 Camaro 1SS 1LE
2008 HHR SS
Old 10-18-2021, 11:26 AM   #9
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
Originally Posted by SS Performance View Post
That's the exact thread I used for my Z06 Conversion shopping list.
Well worth it, especially if you frequent a fast track like I do.
A member here also suggested these titanium shims:
https://knsbrakes.com/c/car-series/1...itanium+Shims+
They keep the heat off the calipers so you can push the pads harder.
My pads were literally on fire at the end of my session and I lost little brake feel.
Also, brake cooling is a big help. I put together my own kit:
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 10-19-2021, 09:16 PM   #10
marathonmann
Thanks guys, what are the options for brake ducts ? Is finding the Z28 ones all there is ? I can't seem to find those anywhere
Old 10-19-2021, 10:25 PM   #11
1LEsteiny
1LEsteiny's Avatar
Drives: 2015 1le
Take the list to a body shop or someone that can order gm parts for a discount they all seam to be available just not as a kit anymore. I just ordered 2 pieces my used eBay set was missing
1LEsteiny is offline   Reply With Quote
