![]() Drives: 2015 Camaro SS Join Date: Mar 2018
Front end Travel Limiters
Who all is using front travel limiters? If you are,what type and did you mount to the lower arms?
Just picked up a set from Motion Raceworks and looking for ideas on how others have welded them up |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Join Date: May 2013
Not sure why you'd need them, what suspension and power level?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Here's how I did mine when I still had factory front struts. I went 1.18 with a stock front strut.
Have since went to a custom valves front and can honestly say you don't need the limiters if you go that route. Hope that helps
Thanks. That’s what I’ve been looking for. I figured a good front strut would also do what I need. Just not ready to dive into those,going to need a trans first.
