![]() Drives: 2010 Camaro SS Join Date: Sep 2021
WTB Rear Control Arms
Looking for upper and lower rear control arms. Was looking for a matched set but let me know what you have.
Scammers please look elsewhere to waste people's time. Thanks. |
Banned
Drives: 2010 LS Join Date: Feb 2021
Assuming REAR, since there are no front Uppers:
There is no matched set, unless you mean, low miles from the same car. Truth be told, the lowers aren't expensive new. I got MOOG ones for about $60 each. I got a set of rear UCAs from FB Marketplace for $100 for the ~10,000 mile pair. 10-15, they're all the same. Buying the rear UCAs with too many miles is ill advised. The inner bushing is a spherical bushing, and they go bad well before that big barrel bushing, which is replaceable. I have as set of those bushings with about 10,000 miles on them I am not going to use. There is a POLY bushing replacement fort he spherical, just changes the feel a little. Same with the ones in the knuckles, there ere two of them too, where the upper and lowers bolt on. 10-15, they're all the same. I will have a set once I replace my rear cradle with an SS one. I will be using the 10,000 mile ones I have, and will have a set with 43,000, and 236,000, and the two outer bushings. The 1LE stuff will probably stay on the cradle I am taking out... Not sure, but the lowers are MOOG on that, factory on the cradle I bought. I plan to sell the whole cradle... Everything except calipers and anchors, but I won't be getting it till next Wed., and I still need the rear section of a driveshaft from an SS or Manual V6. |
Sorry mispoke, looking for the rear trailing arms to start. Poly bushings are fine, but I would like to find a matched set if someone has them from a takeoff or re-sell of their car.
Still looking.
#5 | |
Banned
Yeah, more information helps... I have a pair of stock ones in my shed... I was told they have 17,000 miles on them. I got them with other parts I bought from someone in Canada. The other ones are on that V6 cradle, 234,000 miles on those, but the bushings are replaceable; knuckle and arm side. I was going to buy those ones in that link there, but I just put in an SS cradle, so they have to wait. Little more time with my Crypto investments, if they have those, I will buy them. |
