Old 10-16-2021, 10:15 AM   #1
iLilDark
Drives: Camaro 2013 LT
Npp exhaust
Hi everyone, I'm thinking of putting npp exhaust on my 2013, I currently have one of those "electric mufflers" where it open and close valves inside the muffler with a push of a button, unfortunately my city doesn't allow that and they allow npp ironiccally, is there a way to install this and have it do what the electric mufflers does? Any idea what device do I need to add with it?
Thanks!
iLilDark is offline   Reply With Quote
Old 10-17-2021, 08:44 PM   #2
rdavis
Drives: 2012 SS
Since my car was originally a non NPP car, here's what I did. Put a T in the vacuum line that is routed behind the throttle body. Ran vac line all the way to the trunk . I bought an electric vacuum switch. Ran the line through the switch then split it & connected each to the muffler. Since the mufflers default to the valve open position, when the vac switch is energized it allows engine vac to the mufflers under light load only. Step on it & engine vacuum drops & the valves open. So not a perfect system. With the vacuum switch not energized no vaccum goes to the mufflers so the valves stay in the default open position. Hopes this may give you some ideas. I'm sure there are other ways to do it. Also it is loud on startup for about 2 secs until the engine builds vacuum to close them.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
rdavis is offline   Reply With Quote
Old 10-20-2021, 09:05 PM   #3
PhantomBlack
PhantomBlack's Avatar
Drives: 2014 Camaro 2SS
My car was also non NPP and I hooked it up with an electric vacuum pump I mounted in the spare tire area in the trunk and then ran the switch up to my center console. You can have the valves closed before start up. If anyone is interested I can do a full write up with pics and links to all the parts you need from Amazon. It's pretty easy to set up.
Mods: GPI SS1 VVT cam, TSP long tube headers, LSA conversion, ZL1 fuel pump, ADM FPCM,
DW 700cc injectors, Lingenfelter solid isolator, Dedicated Motorsports ZL1 reinforced brick,
ADM Griptech 2.5 pulley, JLT CAI, Phastek intake scoop,NPP cat-back,
GM 3.91 gears, Eaton Truetrac, etc.
PhantomBlack is offline   Reply With Quote
Old 10-20-2021, 09:30 PM   #4
rdavis
Drives: 2012 SS
That would be cool if you would do that.
Old 10-21-2021, 12:54 PM   #5
PhantomBlack
Ok I'll try and have it done by the weekend.
Old 10-21-2021, 10:33 PM   #6
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
That's so silly... My car has NPP and within the first week of owning it, I pulled the fuse. It's been essentially straight pipes for 80k miles.
terry_b is offline   Reply With Quote
Old 10-22-2021, 02:01 PM   #7
PhantomBlack
Being cammed with headers the valves open vs closed makes a big difference in sound. Plus while cruising valves closed eliminates all the drone. I wouldn't call the fuse pull "straight piped" since you still have mufflers and cats....
Old 10-22-2021, 02:58 PM   #8
terry_b
terry_b's Avatar
That's true, I just shake my head at silly rules
Old 10-22-2021, 04:09 PM   #9
caper
Drives: 2010 IOM 2ss/RS
mine is just installed and open. still def quieter than the straight pipes i had...but if you want quiet and loud...leave your mufflers on and alone, put in an electric cut out. i have one on my turbo downpipe, i am also cammed. it creates some sound lol. honestly the car is damn loud with it closed too (no cats etc.)
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 10-23-2021, 03:40 AM   #10
iLilDark
Well boys the nightmare just arrived, police seized my car and it'll be impound for 6 months along with 12 black points on my license and a fatass fine, I have no idea what to do now since it's my daily car and I live far from work with no transportation options whatsoever, plus about to have my first baby soon, keep me in your prayers my dudes ��
Old 10-23-2021, 11:27 AM   #11
caper
seized it for the mufflers??
Old 10-23-2021, 12:25 PM   #12
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
That's crazy! LOL
In a country that sells that much oil to the US they are worried about exhaust too loud in the desert? lol
Mods:
Old 10-24-2021, 10:31 AM   #13
iLilDark
Yup, Dubai ain't no good environment for any sportscar fans no more, they're seizing every lambo or any car on the road, along with vacuum cleaners like my v6, and I was about to get a zl1 with cams and headers, gotta leave this country now..
Old 10-24-2021, 07:07 PM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Oh wow bro that sucks!! The big one!! Man my heart goes out to ya, hope you can get your car back. That's just not fair, or decent!!! Good luck.
