![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
6 Sp and Rear Diff, Plug fill after fluid levels off or while its still coming out?
Hi, I changed the Tranny and Rear fluids, Do you guys wait until the fluid is done running out to put fill plug in or do you do it when it is still running out? I did it while it was still running out and figured I may have an extra OZ or so of fluid. Both my Rear and Tranny which had factory fill ran out ran I removed the fill and the car was fairly level. The tranny also released air pressure. Should I jack it back up and let the fluid level off?
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Nope, you're fine.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
That’s perfectly fine. I always close the plug on my rear while it’s still coming out.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Banned
Drives: 2010 LS Join Date: Feb 2021
Send it...
