![]() Drives: Chevy Camaro SS Join Date: Jan 2021
2010 camaro ss wont start
Hi all, pretty new here, I have a 2010 ss manual. I dont daily the car, probably drive it every two weeks. It has about 66k miles on it.
It worked fine until recently, it wont start until i keep pumping the gas and it would turn over for like 30 seconds, i would hear it attempt to start then die. I would have to do this process for about 2-3 times then it finally starts. Once its started it runs and doesnt die on me until I turn it off and if I try to start it right after, same process, even when fully warmed up. Im not getting any check lights. I thought the pump died, but if it did, wont it not start at all? Any pointers as to where I should start checking? Changed, plugs and wires last year. Thanks for the help! |
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
Battery or ground cable problems. Search the forums about hard starts , battery and the starter ground.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
I'm thinking air or fuel issues on this one.
I would crank it when cold until just before you think it would start and pull a plug to see if its soaked with fuel or dry. You have a clean air filter in it?
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
Dirty fuel injectors? I cleaned mine a few months ago and they were pretty bad. Lots of dissolved gunk came out.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
![]() ![]() Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Old fuel possibly?
#6 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
NOTE: "pumping" the throttle on a drive by wire fuel injected car just wears out the throttle pedal switch.
If you've updated to a high rise intake and a couple of Holley carbs then never mind the above sentence.
#7 | |
First off on these injected engines, I was told that pumping the gas to get it to start doesn't do anything like the old carbed engines did that had accelerator pumps on them. You get fuel fed by the pump when you turn the key on, then you have fuel pressure to the injectors. I would check your fuel pressure and see what's there, possibility your pump is getting ready to take a crap, or you have some clogged injectors that need attention. Good luck sir..
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Get a fuel pressure gauge and start there.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
#10 | |
