Old 10-31-2021, 03:47 AM   #1
osmana
Drives: Audi
Replacing engine wiring
Greetings,
Has anyone ever replaced an engine wiring harness and gotten code u0100 and it won’t start, it pretty much means the bcm and ecm lost communication, I’ve already checked all my connectors and grounds , everything is solid
Any help would be appreciated moolah vip 888
It’s a 2014 SS, manual
Thank you
osmana is offline   Reply With Quote
Old 11-01-2021, 08:10 PM   #2
barkeater46
Drives: 2010 Camaro 2LT/RS
Not sure of the exact layout of these systems(Mack truck tech), but the CAN data lines will have a 120ohm terminating resistor at each end of a trunk line so the resistors are in parallel. Measured with a Ohm meter at the diag. connector (key off) across the CAN H and CAN L terminals, resistance should be aprox. 60 ohms(1/2 of 120). If measure 120 then one resistor is open or missing.
These resistors can be within a module or plugged into a harness connector that looks like a plain weather cap. Might check the old harness for what might appear to be a unused connector with a cap or plug. CAN data lines are often yellow and green twisted pairs.
barkeater46 is offline   Reply With Quote
Old 11-02-2021, 03:38 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Damn dude. Please stick around these forums.
Old 11-02-2021, 03:50 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^^ lol right??? Now there is some great knowledge that lots of folks could use for certain. Great info barkeater!!
Old 11-02-2021, 04:36 PM   #5
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
I understood all of that the first time I read it. Kept seeing "CAN" so I went & grabbed a beer lol.
acutron42 is offline   Reply With Quote
Old 11-02-2021, 10:57 PM   #6
joekono
joekono's Avatar
Drives: Camaro Convertible 2014 1LT
Tell me about it. Wow!
joekono is offline   Reply With Quote
Old 11-03-2021, 02:31 AM   #7
AlanRubin
Banned
Drives: 2010 LS
These cars have high-speed and low-speed CAN.
The high speed GM LAN bus is terminated with a pair of 120 ohm resistors. One line
is
driven high (3.5 volts) while the other data line is pulled low (1.5 volts) in a
specific sequence to create the signal.
https://atracom.blob.core.windows.ne.../2010_4_22.pdf
U0100 is when any module looses communications with the ECU. You need a scan
tool to see WHICH module set the DTC.
The generic OBD trouble code U0100 is a serious situation where the
signals between the electronic control module (ECM) or the powertrain
control module (PCM) and a particular module have been lost. There could
also be a problem with the CAN bus wiring disrupting communications.
If it were the CAN BUS, you would have a bunch more UCODEs than
that. U0101, lost comms with TCM, for example. U0101 indicates the TCM
is not receiving or transmitting messages on the CAN bus. So, if a
terminating resister was BAD, you'd have a cascade of failures. IF the
GMLAN had failed, you'd have ALL kinds of them. You need to trace
the culprit, and it's NOT the GMLAN itself.
AlanRubin is offline   Reply With Quote
Old 11-04-2021, 08:02 PM   #8
barkeater46
Yeah man, gotta luv data link networks. AlanRubin is on it CAN(controller area network) bus failures drop whole systems. A branch failure (or module on a branch) causes a localized failure where the other modules on the system report lost comms. with that module(s). A good scan tool and schematic wiring diagrams are invaluable weapons.
Unfortunately there often is not a lot of specific t-shoot procedure for data link faults, it comes down to isolating where in the system the breakdown is( i.e. by disconnecting modules or branches and refreshing fault codes to see if new codes pop up or stay same. Schematics lay out how it is all piped together) plus resistance and voltage readings as mentioned above .
Soldier on ! We'll help if we can !
Old 11-04-2021, 08:14 PM   #9
barkeater46
Hey before we get too nuts, remember also the a module that loses power (blown fuse !) is seen by the system as a comm's failure just because it is no longer talking to everybody else on the network.
Old 11-04-2021, 09:45 PM   #10
acutron42
acutron42's Avatar
Very true, look @ the obvious first. If you can scan from the port that part of the network is talking.
Old 11-05-2021, 12:02 AM   #11
joekono
joekono's Avatar
I can solve a Rubik's Cube in under 20 minutes.
Old 11-08-2021, 05:46 PM   #12
barkeater46
It takes me about an hour. Those color stickers are hard to peel..........
Old 01-11-2024, 06:50 AM   #13
SlowLS1
SlowLS1's Avatar
A spam thread that ended up having productive thoughts and knowledge. LOL
First post was spam, last post was spam, and everything in between was constructive.
SlowLS1 is offline   Reply With Quote
Old 01-11-2024, 10:34 AM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yeah right??? These spam posts usually don't turn out to well, if at all!!
