11-02-2021, 07:18 PM | #1 |
Drives: 2013 Camaro 2SS, L99 Join Date: Jul 2018
:cry: Engine Cover WET
What the $hit is THIS?!
11-03-2021, 01:32 PM | #2 |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
Looks like a red arrow to me.
On the real, though, did you check your weatherstripping to rule out rain/hose water? Have you tried wiping the fluid with a white paper towel to determine its color and consistency? |
11-03-2021, 06:19 PM | #3 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
Pull the cover and see if there’s an issue underneath. As Elder asked, did it recently rain or did you wash the vehicle?
11-04-2021, 06:42 PM | #4 |
Also can't really tell from the pic, it's kinda fuzzy, but it almost looks like his rubber weather strip might be missing. That could allow some water to enter from the cowl area.
11-04-2021, 07:20 PM | #5 |
Just thought about this one too, the tubing from the windshield washer bottle runs just inside the front fender edge on the driver side and up to the squirters on the hood. Check the tubing for cracks or a possible pin hole maybe causing fluid to run down and deposit on the engine cover, or that one of them might of came loose. Just a thought.
11-05-2021, 12:40 PM | #6 | |
Totally unrelated to this thread, but your post just reminded me: I need to check my windshield wiper container and hoses. I'm losing fluid, somewhere, but don't see any signs of leakage, below. Guess I can pull the tire and do an inspection this Sunday... |
11-05-2021, 05:14 PM | #7 | |
11-07-2021, 09:12 AM | #8 | |
I just checked those hose ends, and they're dry as the Sahara. No signs of fluid on the underside along the frame, either. I guess I'll pull the tire and look behind the wheel well to see if it's dripping there and just not making it to the ground. Who knows. Maybe I'm just going insane in my older age and losing my mind... Oh, and sorry for thread hijack, OP. Let us know what you find out about the fluid on your engine cover. |
11-15-2021, 04:20 PM | #9 |
Hey there kbear951, did you ever find where the water came from??
11-28-2021, 09:10 PM | #10 |
Yesterday my lifter tick became a lifter knock so I had it towed to a shop. I pulled off the engine cover and saw the right side of the engine was wet. I don’t think the two are related? Being that I still owe a shitload of money on the car, I guess I’m replacing the lifters. Still trying to decide if I should just go ahead and do an LS3 conversion +/- cam swap? Idk bc I live in California and was just told by a mechanic that next year mods will be illegal here? Idk how the hell they plan for that to work….but…. Any tips on how to find a shop that actually knows what they are doing and how to do this sort of work on these cars?
11-29-2021, 11:03 AM | #11 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I would go ahead and do the conversion, I am not quite sure how they can tell as it is internal and can be tuned to run clean.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
11-29-2021, 11:24 AM | #12 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
11-29-2021, 12:54 PM | #13 |
Gotcha, So the inspection station has to plug in and check tune? That's crazy so what are all the guys supposed to do before this takes affect? Grand fathered in? Sell Car/ De tune.
11-29-2021, 01:00 PM | #14 |
