![]() ![]() Drives: 2010 Camaro 1SS (BLACK) Join Date: Jan 2010
Brakes and rotors.
Hey guys so it’s time for some new brakes and rotors and wanted to get some good options out there. Would like something that’s quiet and minimal brake dust. It’s for daily driving no track.
Have a 2010 SS LS3
![]() ![]() Drives: 2015 Z/22 Join Date: Aug 2015
Many including hardcore Camaro handling/racing experts such as JusticePete always suggested the stock pads and rotors are all you need for daily driving.
An Rock Auto is probably your best bet for stock parts.
Orange Krush II
Yep, as mentioned above. I replaced mine when it was time with OEM rotors and pads. Went with the AD Delco Professional semi metallic pads. They stop really nice, quiet AND are pretty much dust free, and my Camaro is a daily. I'm happy with them.
KaBoom1701
I track my car and I always use stock OEM pads....
Mods:
#6 |
Awesome thank you for the replies and anyone know the min for the front and rear rotor specs?
