Old 11-05-2021, 12:10 AM   #1
jesse121pm
jesse121pm's Avatar
Drives: 2012 Camaro 2ss 45th anniversary
Just bought a camaro first time mods
Hey everyone I just bought a 2012 camaro 2ss 45th anniversary edition. It already has a straight pipe and k&n intake when i bought it. I need some first time mods to give me some more power. I am always on this fourm and I know you guys have really good advice. Thank you (Btw its a 6 speed manual with LS3)
jesse121pm is offline   Reply With Quote
Old 11-05-2021, 12:43 AM   #2
joekono
joekono's Avatar
Drives: Camaro Convertible 2014 1LT
Congrats on your purchase and welcome. There are MANY people here that can give you great advice on getting that beautiful Gen 5 rollin with more horses. I just like crusin with my girl and trying to keep swirls and scratches off the car. So, if i can give you any advice, because it's a 45th edition, keep her lookin good(that shouldn't be too hard).
joekono is offline   Reply With Quote
Old 11-05-2021, 05:55 AM   #3
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Congrats & welcome!
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 11-05-2021, 09:18 AM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
First steps are intake headers tune. Not sure how the K&N's work I sold the one that came with my car and bout a CAI intake much better for cold air. speed engineering headers work pretty well for cheap money, I do recommend getting them coated. Jannetty charged me $300 to have them coated inside and out.
3.91 gears make a big performance difference. lower control arms and trailing arms are good when you start getting wheel hop. Cradle bushings if you still have hop after the arms.
Beyond that you will start looking at a cam, or FI or both. Heads flow amazingly well on these so that is far down on the list of mods.
Greenhornet2 is offline   Reply With Quote
Old 11-05-2021, 09:46 AM   #5
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Another Christmas the kids will go without while dad’s Camaro gets the goodies! Congrats. T’is a healthy addiction. Well, sorta.
Moto-Mojo is offline   Reply With Quote
Old 11-05-2021, 10:43 AM   #6
Axe55
Drives: 2012 Camaro SS
Welcome and congrats! I'd recommend the long tube headers and a tune as a starting point. Also, the LTs make the car sound so good, after doing them I wish I had done them the day I bought the car. The trailing arms, toe rods and cradle bushings (solid or inserts) are also good because they help eliminate wheel hop. None of those are that expensive or hard to install either.
After that, if you've been browsing the forums, you know the sky's the limit!
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
Axe55 is offline   Reply With Quote
Old 11-05-2021, 11:00 AM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
As said, headers for sure. Tunes are less necessary for M6 cars, but you would pick up a few hp.
What are you going to use it for, drag racing, auto cross, road course?
Depending on the miles it might need some suspension upgrades. It will definitely benefit from 1LE sway bars and radius arm inserts. AmericanMuscle had the Whiteline inserts for $20 about a week ago. Factory bars are cheap if you can still get them. If it has a lot of miles, it might be a good time for new shocks.
Some might say cam, but if you think you will end up going forced induction, I would wait until you do that to choose a cam.
Not many guys still running nitrous, but that is a quick way to knock a second or more off your ET.
Then there are tires...
Old 11-05-2021, 11:41 AM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome sir!! Welcome to the family of FINE Camaro folks!! The first thing you are gonna want to do is plant 2 money trees, one for you and one for your girlfriend/wife!! Lots of cool mods you can do with these Camaro's. For performance as mentioned, LT's and a tune will get you going in the right direction. Then depending on what the car is going to be mostly used for, the sky is the limit!! Enjoy that awesome Camaro...
Old 11-05-2021, 12:06 PM   #9
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
Like everyone has said: Intake, Exhaust, Headers, & Tune.
Those tend to be the default "go-to" things that everyone does and benefits the car in all cases.
Mine also came with a K&N Blackhawk intake and it works alright, but I'm looking at switching out to a CAI one.
Long tube headers wake up the LS and are pretty much a "must do". You will need a tune to get the most from them and especially if you delete the cats.
If you want more volume, get yourself a cat-back exhaust system. Plenty out there!
Another simple and cheap mod would be a oil catch can.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 11-05-2021, 12:06 PM   #10
Moto-Mojo
Moto-Mojo's Avatar
Or just move to California, where just owning a dino-fueled Camaro will be a felony someday soon. You can use what you save on mods for legal representation!
Old 11-05-2021, 12:29 PM   #11
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
And Gas
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 11-05-2021, 12:37 PM   #12
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
Definitely LT headers are a must, 40-50 HP can be gained with a dyno tune. I gained 216 HP with the mods listed below. I don't care for am changes because the car never drives the same.
sscamaro is offline   Reply With Quote
Old 11-06-2021, 09:24 PM   #13
jcampos
jcampos's Avatar
Drives: 2014 Chevy Camaro SS
Get LT's, CAI, high rise intake manifold, a huge TB, ported or racing heads and a fatass cam paired with gears and suspension work and put down mid 500's on a NA build
jcampos is offline   Reply With Quote
Old 11-07-2021, 02:06 AM   #14
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I agree with most others have said. Long tubes, cold air intake (I use Cold Air Inductions), and a dyno tune for the most power you can get. And then if you are not satisfied with the power increase go to a cam next. But I definitely like the way long tubes and a tune feel.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
mods
